查看: 186|回复: 8
The last update has totally wrecked this app!!!
 楼主| 发表于 2019-4-1 13:00:10 来自手机 | 显示全部楼层 |阅读模式
{"text":"if it's not broken don't change it is the advice I give. whatever the intent was updating and changing how app worked has destroyed a good thing. the simplicity of using this app has been complicated without any obvious benefits. please go back to what works... please and thanks !!!","videos":"[]","pics":"[]","canComment":true}
发表于 2019-4-3 21:32:23 来自手机 | 显示全部楼层
{"replyTo":"","text":"Must be your phone dude. The newest update is awesome!","replyToPid":0}
发表于 2019-4-1 23:35:10 来自手机 | 显示全部楼层
{"replyTo":"","text":"Hi there! We apologize for the inconvenience that the latest update has caused. However, as the technology on both Android and iOS continuously improve, Trucker Path must implement changes to become compatible with the new operating system requirements. If you need help navigating the app with its new updates, don't hesitate to give us a call at our 24/7 Customer Service hotline at 757-941-7806. We appreciate your continuous support.\r\n\r\nHaul Proud, Haul Safe!","replyToPid":0}
发表于 2019-4-2 02:15:49 来自手机 | 显示全部楼层
{"replyTo":"","text":"The update is actually better! lovin this more than the previous version!","replyToPid":0}
发表于 2019-4-3 21:37:44 来自手机 | 显示全部楼层
{"replyTo":"","text":"*** Completely agree !!! ***","replyToPid":0}
发表于 2019-4-5 11:33:19 来自手机 | 显示全部楼层
{"replyTo":"","text":"How do I find the turn by turn on here before I could see it now that I am a gold member it’s not to be found. I have specific routing I have to use but most times your right on with it. But I still need to see turn by turn navigation ","replyToPid":0}
发表于 2019-4-7 19:27:50 来自手机 | 显示全部楼层
615914 发表于 2019-04-01 15:35:10 Hi there! We apologize for the inconvenience that the latest update has caused. However, as the technology on both Android and iOS continuously improve, Trucker Path must implement changes to become compatible with the new operating system requirements. If you need help navigating the app with its new updates, don't hesitate to give us a call at our 24/7 Customer Service hotline at 757-941-7806. We appreciate your continuous support.\r\n\r\nHaul Proud, Haul Safe!
","text":"it's one thing to be moving forward with technology and offering great new things to do other things 2 release an untested and spuggy application. I will spend some time going through the bugs at a later date","replyToPid":7650}
发表于 2019-4-7 20:35:54 来自手机 | 显示全部楼层
{"replyTo":"","text":"poorly tested, buggy release \n\n- former software developer","replyToPid":0}
发表于 2019-4-10 12:16:01 来自手机 | 显示全部楼层
{"replyTo":"","text":"uninstall the app and reinstall it that's what I did and it work","replyToPid":0}
GMT+8, 2026-4-18 23:35 , Processed in 0.092553 second(s), 24 queries .
