查看: 144|回复: 5
Miles Are Not Correct On This App...
 楼主| 发表于 2019-4-1 12:38:25 来自手机 | 显示全部楼层 |阅读模式
{"text":"I Have Not Done The Math...Yet...\nBut\n...The Miles Are Off ?% From The GPS Miles In Distances...The Longer The Distance...The More Off In Miles it Is!!!\n...Making It Very Difficult To Trust Your Trip Planning Correctly Without Needing To Double Check Everything On Your GPS!!!","videos":"[]","pics":"[]","canComment":true}
发表于 2019-4-1 23:14:22 来自手机 | 显示全部楼层
{"replyTo":"","text":"Hi Cäri! We are sorry for the confusion on the distances on the app. Please be advised that within the \"place information\", it shows you the air mile distance which is the straight distance between two places. If you tap on \"Truck Routing\" it shows you the driving distance is the distance over the road from your current location to your destination. You will have different route options and each will show you the driving distance. If you need further/immediate assistance, don't hesitate to call our 24/7 Customer Service hotline at 757-941-7806. Have a great day ahead!","replyToPid":0}
发表于 2019-4-1 12:53:18 来自手机 | 显示全部楼层
{"replyTo":"","text":"Air miles","replyToPid":0}
 楼主| 发表于 2019-4-1 12:57:14 来自手机 | 显示全部楼层
{"replyTo":"","text":"lol","replyToPid":7571}
 楼主| 发表于 2019-5-30 19:39:43 来自手机 | 显示全部楼层
615914 发表于 2019-04-01 15:14:22 Hi Cäri! We are sorry for the confusion on the distances on the app. Please be advised that within the \"place information\", it shows you the air mile distance which is the straight distance between two places. If you tap on \"Truck Routing\" it shows you the driving distance is the distance over the road from your current location to your destination. You will have different route options and each will show you the driving distance. If you need further/immediate assistance, don't hesitate to call our 24/7 Customer Service hotline at 757-941-7806. Have a great day ahead!
","text":"I Truly Appreciate The Actual Miles You Added To The App...It Makes My Trucking Life Sooo Much Easier!!!","replyToPid":7643}
发表于 2019-6-2 20:14:53 来自手机 | 显示全部楼层
{"replyTo":"","text":"if you're going from Columbus  OH to Indianapolis by way of Cairo, Egypt air miles","replyToPid":0}
GMT+8, 2026-4-18 23:35 , Processed in 0.091672 second(s), 24 queries .
