查看: 450|回复: 16
What’s the axle weight limitations for 53’ tandem trailers?
 楼主| 发表于 2019-3-30 20:11:01 来自手机 | 显示全部楼层 |阅读模式
{"text":null,"videos":"[]","pics":"[]","canComment":true}
发表于 2019-4-20 03:00:14 来自手机 | 显示全部楼层
{"replyTo":"","text":"Start on page A16 of your RM Road Atlas.","replyToPid":0}
发表于 2019-3-31 04:49:07 来自手机 | 显示全部楼层
{"replyTo":"","text":"but all of that depends on the weight rating on tires","replyToPid":0}
发表于 2019-3-30 20:38:27 来自手机 | 显示全部楼层
{"replyTo":"","text":"34000","replyToPid":0}
发表于 2019-3-30 20:57:26 来自手机 | 显示全部楼层
{"replyTo":"","text":"different from state to state Rand McNally has them listed in the back of your map book","replyToPid":0}
发表于 2019-5-31 23:04:04 来自手机 | 显示全部楼层
{"replyTo":"","text":"Depending on the state you are in varies the answer. In general to stay safe in all of the combine lower 48, you can normally not exceed 80,000 LBS Gross Vehicle Weight. This equalls out to 12,000 Steer, 34,000 Drive (tandom), 34,000 Trailer (tandom) = 80,000 Gross Vehicle Weight. Those are the normal \"maximum\" weight for that set up. If you were to \"spread\" your trailer axel you may have a weight of 20,000 per axel but to not exceed the 80,000 max Gross Vehicle Weight. So to add it 12k S, 34k D, 20k T1, 20k T2 = 86k GVW. That is bad. So you need to take 6K from Drives and go from there. But that os the best general answer I can give for a general question. Please contact your safety department or DOT agency for more specialized inquiries.","replyToPid":0}
发表于 2019-4-20 03:06:29 来自手机 | 显示全部楼层
{"replyTo":"","text":"Yes that info is in the Atlas as well. A26 starts restricted road section.","replyToPid":0}
发表于 2019-4-20 02:45:51 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"34k on tandems or 20k per axle on at least a 10' spread"}
发表于 2019-3-31 02:54:58 来自手机 | 显示全部楼层
{"replyTo":"","text":"34k On Tandem Group @ 41’ From King Pin\n17k per Axle","replyToPid":0}
发表于 2019-3-31 04:45:15 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"Virginia is 20k for single axle and 34k on tandem but Florida is 22k on single and 44k on tandem"}
发表于 2019-4-19 21:30:26 来自手机 | 显示全部楼层
{"replyTo":"","text":"Steers - 12,000 lbs.\nBoth drives and rears - 34,000 lbs.","replyToPid":0}
GMT+8, 2026-3-21 15:36 , Processed in 0.561906 second(s), 24 queries .
