查看: 555|回复: 21
New driver here...
 楼主| 发表于 2019-3-30 07:38:05 来自手机 | 显示全部楼层 |阅读模式
{"text":"hi everyone. i want to know which gps and Bluetooth headset i should buy ?\nThank you","videos":"[]","pics":"[]","canComment":true}
发表于 2019-3-31 06:04:03 来自手机 | 显示全部楼层
{"replyTo":"","text":"My opinion,  is that even though you want a \"truck gps\" do not, and I do mean, do not rely on it. Most time's it'll take you on a longer route regardless of route settings, such as \"faster route\" or \"shortest route\". I do have a Rand Mcnally TND 730, but I also use Google maps, as it is a lot more accurate than these truck gps's. Do be aware of routes as Google maps isn't a trucker's gps. But 9 x's out of 10 it's on point. Also download Trucker's Path, you can set your location and then transfer that route to Google maps. And as stated ALWAYS check where you are going to go before you get on the road on maps in satellite view.  \nOn the headset I have two I use and people on the other end never complain about background noise.  Blue Parat VXI 450 (Ebay for $40) and Plantronics (bought on OfferUp $20). \nBest of luck out there and watch your six on these roads and stops..","replyToPid":0}
发表于 2019-3-30 09:28:10 来自手机 | 显示全部楼层
{"replyTo":"","text":"Rand McNally gps and blue parrot headset vxi 250 ","replyToPid":0}
发表于 2019-3-30 09:12:25 来自手机 | 显示全部楼层
{"replyTo":"","text":"Blue parrot ","replyToPid":0}
发表于 2019-3-30 12:32:36 来自手机 | 显示全部楼层
{"replyTo":"","text":"even with a good GPS you'll still need  a Rand McNally map book . always map it out fist and use the gps as a guide plus  there is lots of information in the like fed and state regulations that you'll need from time to time","replyToPid":0}
发表于 2019-4-2 07:06:06 来自手机 | 显示全部楼层
{"replyTo":"","text":"Rand mcnally da gps te plantronic da headset laila y ","replyToPid":0}
发表于 2019-4-2 12:34:34 来自手机 | 显示全部楼层
{"replyTo":"","text":"I have a Garmin dezl 770...picked it up over a year ago and it does a pretty decent job. It can reroute you if there is a traffic delay up ahead on your route which I’ve done a couple times and it does a good job with updated ETAs in that respect as well. For headsets blue parrott.","replyToPid":0}
发表于 2019-3-30 10:17:05 来自手机 | 显示全部楼层
发表于 2019-4-11 05:11:25 来自手机 | 显示全部楼层
{"replyTo":"","text":"I have a Rand McNally road atlas, a Rand McNally Tnd 540, a Garmin dezl 580 and a Blue Parrot 450.  The 2 GPSes always have some sort of problem. All truck GPSes will screw you at some point. Blue Parrot has a very good warranty. If it breaks, contact them and they will send you a new one.","replyToPid":0}
发表于 2019-4-10 10:14:50 来自手机 | 显示全部楼层
{"replyTo":"","text":"I use rand McNally and blue parrot, no problems with either ","replyToPid":0}
发表于 2019-4-3 15:06:49 来自手机 | 显示全部楼层
{"replyTo":"","text":"Bluetooth 250. Garmin 760. Buy them on Amazon","replyToPid":0}
发表于 2019-3-30 11:44:51 来自手机 | 显示全部楼层
{"replyTo":"","text":"I really like the planatronics voyager bluetooth head set its small, easy to work with.","replyToPid":0}
发表于 2019-3-30 21:08:22 来自手机 | 显示全部楼层
{"replyTo":"","text":"I just wear the blue tooth offered at the store. It’s cheaper and works just fine. You’re u don’t need a headset. You probably just want one because you believe it’s what truckers wear. You don’t need it. I wouldn’t spend $100 or more on a headset. You’ll be disappointed. It does what all Bluetooths that cost $40 do. I would save my points and then get one. I personally don’t like the bulky goofy looking headset. ","replyToPid":0}
发表于 2019-3-31 05:14:37 来自手机 | 显示全部楼层
608600 发表于 2019-03-30 03:44:51 I really like the planatronics voyager bluetooth head set its small, easy to work with.
","text":"I second that.","replyToPid":7019}
GMT+8, 2026-4-17 23:06 , Processed in 0.131762 second(s), 24 queries .
