查看: 768|回复: 16
New Cascadia MPG
 楼主| 发表于 2019-3-29 06:44:45 来自手机 | 显示全部楼层 |阅读模式
{"text":"What's MPG on 2018-2020 Cascadia trucks?","videos":"[]","pics":"[]","canComment":true}
发表于 2019-4-15 22:16:49 来自手机 | 显示全部楼层
{"replyTo":"","text":"I drive a constant 65, full aerokit, adaptive cruise and aerotrailer. My lifetime average on this truck is 8.5 the lighter the load the better the mpg. At 45k in the trailer I get 7-7.5, less than 20k in the trailer I can get up to 9-9.5. Bobtailing I get 10+","replyToPid":0}
发表于 2019-9-2 07:49:38 来自手机 | 显示全部楼层
{"replyTo":"","text":"My 2019 automatic cascades with dd13 is at 9.15 lifetime with 107.000","replyToPid":0}
发表于 2019-8-31 14:14:39 来自手机 | 显示全部楼层
{"replyTo":"","text":"7.9 on 2019 cascadia and I run hard east 2 west pulling mountains average 30 to 42 thousand","replyToPid":0}
发表于 2019-4-5 01:16:05 来自手机 | 显示全部楼层
{"replyTo":"","text":"With drag guides under and behind I got 8.1 MPG carrying 34,000 lbs of asparagus.","replyToPid":0}
发表于 2019-4-10 07:34:17 来自手机 | 显示全部楼层
{"replyTo":"","text":"Most of my loads are 5k-20k pounds with a lot of travel in the Eastern mountains and I'm averaging 7.6 in a 2019.","replyToPid":0}
发表于 2019-11-18 07:45:41 来自手机 | 显示全部楼层
{"replyTo":"","text":"I have a 2018 Cascadia and the way this company has it set up I get 6.5 MPG.  Their computer says 7.7 but when you put paper to pen milage to gallons its a full 1mpg less than what they want. Wish it could get better","replyToPid":0}
发表于 2019-10-10 19:38:50 来自手机 | 显示全部楼层
{"replyTo":"","text":"I have a 2018, my average is 9.8mpg","replyToPid":0}
发表于 2019-8-20 07:04:36 来自手机 | 显示全部楼层
783238 发表于 2019-08-19 23:02:51 my lowest in mine was 9.9 I have gotten up to 13
","text":"that is in a 2020","replyToPid":185635}
发表于 2019-8-20 07:02:51 来自手机 | 显示全部楼层
{"replyTo":"","text":"my lowest in mine was 9.9 I have gotten up to 13","replyToPid":0}
发表于 2019-4-11 01:21:19 来自手机 | 显示全部楼层
642582 发表于 2019-04-04 17:16:05 With drag guides under and behind I got 8.1 MPG carrying 34,000 lbs of asparagus.
","text":"were you driving 60MPH? cause i have got 8MPG with anothing above 20k LB usually i drive at around 68MPH","replyToPid":8807}
发表于 2019-3-30 21:59:59 来自手机 | 显示全部楼层
{"replyTo":"","text":"I'm getting 7.0 - 7.5 on my 2018","replyToPid":0}
发表于 2019-4-5 01:16:25 来自手机 | 显示全部楼层
{"replyTo":"","text":"Model 3019","replyToPid":0}
发表于 2019-4-5 01:16:33 来自手机 | 显示全部楼层
{"replyTo":"","text":"2019","replyToPid":0}
发表于 2019-4-11 01:13:23 来自手机 | 显示全部楼层
{"replyTo":"","text":"on a nice weather with 40K LB you could average 7to 7.5MPG but winter i was getting around 6.5MPG to 7MPG","replyToPid":0}
GMT+8, 2026-4-17 08:05 , Processed in 0.138105 second(s), 24 queries .
