查看: 118|回复: 1
Questions about interstate permits
 楼主| 发表于 2019-3-27 23:36:56 来自手机 | 显示全部楼层 |阅读模式
{"text":"A question has come up regarding intrastate permits. I was under the impression that even if you have interstate authority - that if you ever haul intrastate loads in some states - that they require you to have a permit to do so. Your interstate authority does not necessarily allow you to haul intrastate loads in some states? Is this correct? Or are intrastate permits only for carriers domiciled in a state but never leave it?","videos":"[]","pics":"[]","canComment":true}
发表于 2019-4-1 20:51:34 来自手机 | 显示全部楼层
{"replyTo":"","text":"I’d say most, if not all, states require intrastate authorities to pick and deliver loads within one state. I do not know if there are states that do not require intrastate authorities. The inter-state authority allows you to pick a load from one state and deliver it to only a different state, but some states have additional requirements to operate in their states even with the inter-state authority. OR, NM, KY, and NY require a weight-distance permit to be able to operate in their states.","replyToPid":0}
GMT+8, 2026-4-15 12:09 , Processed in 2.677618 second(s), 25 queries .
