查看: 637|回复: 13
How do you look for loads when you become owner operator?
 楼主| 发表于 2019-3-27 11:56:20 来自手机 | 显示全部楼层 |阅读模式
{"text":"","videos":"[]","pics":"[]","canComment":true}
发表于 2019-3-28 11:55:46 来自手机 | 显示全部楼层
{"replyTo":"","text":"create a customer base","replyToPid":0}
发表于 2019-3-27 12:10:26 来自手机 | 显示全部楼层
{"replyTo":"","text":"Truckloads? ","replyToPid":0}
 楼主| 发表于 2019-4-1 23:02:15 来自手机 | 显示全部楼层
{"replyTo":"","text":"Pe_Trans. thank you for your time and help i really appreciate it","replyToPid":0}
发表于 2019-5-19 20:59:10 来自手机 | 显示全部楼层
{"replyTo":"","text":"You can or you can actually join a small company that for 10% of rate they will let you use their authority and hook you up with insurance ( that you pay cost for). So you can use its brokers or it will book you loads that you have options of which load to take....\n443-822-3093\nCall if interested ","replyToPid":0}
发表于 2019-4-29 01:24:47 来自手机 | 显示全部楼层
{"replyTo":"","text":"truckers edge from DAT is main, but when your MC is new, a lot of people won't give you work, Uber, convoy, and Next trucking will. Makes no sense, they want to claim liability for not giving you work, but you're fully insured like everyone else. Fuck the system and everything it stands for.","replyToPid":0}
发表于 2019-4-1 20:57:12 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"DAT is the largest and most legit load board at the moment. Other load boards are coming up, particularly in the form of apps. The other well known and trustworthy load board is (internet) Truck Stop. To be able to use the DAT load board, you must have a USDOT#. DAT must verify that you are a legal and registered carrier. This is mostly to reduce fraud from both carriers and brokers. It’s a good thing. You don’t want a load board that has brokers that won’t pay. "}
 楼主| 发表于 2019-3-28 11:30:23 来自手机 | 显示全部楼层
{"replyTo":"","text":"yes??","replyToPid":0}
 楼主| 发表于 2019-3-29 03:10:19 来自手机 | 显示全部楼层
{"replyTo":"","text":"thank you","replyToPid":0}
发表于 2019-4-1 00:43:46 来自手机 | 显示全部楼层
{"replyTo":"","text":"On line:\nData.com\nGetloaded.com\nTruckstop.com","replyToPid":0}
 楼主| 发表于 2019-4-1 11:57:48 来自手机 | 显示全部楼层
{"replyTo":"","text":"10wg2...THANK YOU SO MUCH","replyToPid":0}
发表于 2019-4-2 18:12:57 来自手机 | 显示全部楼层
{"replyTo":"","text":"in addition,get on brokers email load list,and go to their web sites.Many have free load boards of their own....also get their apps","replyToPid":0}
GMT+8, 2026-4-15 14:03 , Processed in 0.082854 second(s), 24 queries .
