查看: 171|回复: 5
Trailer locks
 楼主| 发表于 2019-3-26 05:13:12 来自手机 | 显示全部楼层 |阅读模式
{"text":"Most of my shippers/receivers like it when they see me at the trailer door removing a lock when docking, or putting one on when leaving but I am tired of replacing locks because they have gotten so rusted/corroded, that they are useless and unable To (un)lock because of it.  ","videos":"[]","pics":"[]","canComment":true}
发表于 2019-3-26 06:29:51 来自手机 | 显示全部楼层
{"replyTo":"","text":"keep them sprayed down with a good Lube that will penetrate and prevent water from getting inside the log","replyToPid":0}
发表于 2019-3-26 19:43:07 来自手机 | 显示全部楼层
{"replyTo":"","text":"WD-40 isn't just a lube, it was designed to repel water.","replyToPid":0}
发表于 2019-3-27 01:27:07 来自手机 | 显示全部楼层
{"replyTo":"","text":"I agree with them. Just use WD-40.","replyToPid":0}
发表于 2019-3-27 03:36:07 来自手机 | 显示全部楼层
{"replyTo":"","text":"Its settles. USED WD-40","replyToPid":0}
发表于 2019-3-28 05:48:34 来自手机 | 显示全部楼层
{"replyTo":"","text":"I agree with them. Use a lubricant or WD40","replyToPid":0}
GMT+8, 2026-2-4 12:30 , Processed in 0.055600 second(s), 24 queries .
