查看: 254|回复: 4
Weigh Stations.
 楼主| 发表于 2019-3-24 23:37:56 来自手机 | 显示全部楼层 |阅读模式
{"text":"I’ll be leaving Mesa AZ soon for El Paso TX with a F250 pickup pulling a empty 3-horse trailer. \nMust I pull into weigh stations or drive by?\nThanks,","videos":"[]","pics":"[{\"description\":\"\",\"height\":620.0,\"name\":\"\",\"url\":\"\",\"width\":828.0}]","canComment":true}
发表于 2019-3-26 10:35:45 来自手机 | 显示全部楼层
{"replyTo":"","text":"if your not for hire not running a dot or mc number your good. personal use you dont have to. what's your pickup registered under? commercial or personal","replyToPid":0}
发表于 2019-3-26 08:15:31 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"Some states require it. If you want to be on the safe side, just stop on each weigh station, or be prepared to be pulled over by a cop. I think it also has to do with the weight of your entire truck and trailer. You can weigh your truck at a CAT scale in just about any major truck stop. They charge about $11.50.\n\nYou can also try calling a weigh station. This app should display the weigh station on a map. Some weigh stations have phone numbers available. "}
发表于 2019-3-25 04:13:23 来自手机 | 显示全部楼层
{"replyTo":"","text":"Would like to know also ","replyToPid":0}
发表于 2019-3-25 04:33:21 来自手机 | 显示全部楼层
{"replyTo":"","text":"Only if it’s company wise.  If you’re own needs you don’t have too. ","replyToPid":0}
GMT+8, 2026-4-15 12:08 , Processed in 0.075892 second(s), 24 queries .
