查看: 465|回复: 6
Driver Pay question
 楼主| 发表于 2019-3-20 04:58:46 来自手机 | 显示全部楼层 |阅读模式
{"text":"So when paying a Driver lets say 30%. Should that be after fuel cost also? I Plan on putting a speed limiter on my trucks so that they aren't blowing all the money on Fuel anyway.  ","pics":"[]","canComment":true}
发表于 2019-3-20 06:08:24 来自手机 | 显示全部楼层
{"replyTo":"","text":"if you're planning on putting somebody else in the truck but if you was the owner-operator driving your own truck making 30% after fuel I would go haul for somebody else","replyToPid":0}
发表于 2019-3-20 08:53:57 来自手机 | 显示全部楼层
{"replyTo":"","text":"It should be 30% after the % cut, whatever it is. Not after fuel, etc. I would never run for anyone that pays me % after cut, plus fuel etc. ","replyToPid":0}
发表于 2019-3-20 09:36:18 来自手机 | 显示全部楼层
{"replyTo":"","text":"30% of gross , fsc is to the truck not the driver","replyToPid":0}
发表于 2019-3-20 12:00:46 来自手机 | 显示全部楼层
{"replyTo":"","text":"What kind of freight has to be taken into consideration driver being compensated for fuel mileage went over a certain mpg average goal is met as an incentive for good operating there’s a lot of things that go into factor for thisLike is the driver going to be a contract labor 1099 or are you going to pay the taxes out of his check etc.","replyToPid":0}
发表于 2019-3-21 05:26:17 来自手机 | 显示全部楼层
289718 发表于 2019-03-19 22:08:24 if you're planning on putting somebody else in the truck but if you was the owner-operator driving your own truck making 30% after fuel I would go haul for somebody else
","text":"I'd probably do the same. HAHA","replyToPid":5261}
发表于 2019-3-22 22:13:01 来自手机 | 显示全部楼层
{"replyTo":"","text":"30% of the load means before expences ie fuel etc. if you pay 30% after expences that means the driver is paying your operating cost.","replyToPid":0}
GMT+8, 2026-4-15 10:04 , Processed in 0.078172 second(s), 24 queries .
