查看: 461|回复: 6
False log violation question
 楼主| 发表于 2019-3-20 04:57:29 来自手机 | 显示全部楼层 |阅读模式
{"text":"Got hit with a false log violation. Wasn’t speeding or anything. Officer didn’t have a reason to stop me. Not sure why he did. I’m an owner operator running my own #s and only 1 truck. How will this affect my CSA score? Will this cause me to get red lighted more often now going thru scales. Anything that I can do to help offset the impact? ","pics":"[]","canComment":true}
发表于 2019-3-21 05:37:37 来自手机 | 显示全部楼层
628506 发表于 2019-03-20 00:56:54 They don’t need a reason to stop you. 1 log violation will not affect you near what you think, but it does a little. You only having 1 truck hurts you too because you don’t have other drivers to help your overall score. But as long as you stay clear awhile you’ll be fine.
","text":"+1 on this","replyToPid":5273}
发表于 2019-3-20 08:56:54 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"They don’t need a reason to stop you. 1 log violation will not affect you near what you think, but it does a little. You only having 1 truck hurts you too because you don’t have other drivers to help your overall score. But as long as you stay clear awhile you’ll be fine. "}
发表于 2019-3-27 06:32:46 来自手机 | 显示全部楼层
{"replyTo":"","text":"What you have to think about is how often you get inspected. If you’ve only been inspected one time and they had a logbook violation and put you out of service then you have a 100% out of service record.  That’s going to red flag you. The more you get inspected with good inspections the less that violation matters","replyToPid":0}
发表于 2019-3-20 12:15:33 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"I got one for not writing the BOL number on it."}
发表于 2019-3-20 06:09:59 来自手机 | 显示全部楼层
{"replyTo":"","text":"are you running an Eld or running paper and he can pull you over for whatever reason he may want and as far as your score yeah it's kind of heard it kind of knock it down some but it doesn't matter if you get the red light or not it's all up to them","replyToPid":0}
发表于 2019-4-21 12:42:21 来自手机 | 显示全部楼层
26080 发表于 2019-03-20 04:15:33 I got one for not writing the BOL number on it.The C*cksucker sheriff that hangs around on the Katy,TX overpass.
","text":"Your right. The officer should ignore the rules for you. LOL","replyToPid":5283}
GMT+8, 2026-4-18 02:50 , Processed in 0.090015 second(s), 24 queries .
