查看: 290|回复: 8
How long do you warm up your rig before driving?
 楼主| 发表于 2019-3-19 04:20:56 来自手机 | 显示全部楼层 |阅读模式
{"text":"i own a DD15 and I want to know the warm-up period before driving it. I usually do 15 min but I guessing I need half and hour before I start driving.\n\n\nAny inputs?","pics":"[]","canComment":true}
发表于 2019-3-20 12:17:39 来自手机 | 显示全部楼层
631628 发表于 2019-03-19 16:16:01 Well, I have a rule of thumb that if I'm getting warm air from the HVAC system I'm good to go, most engine wear occurs during a warm-up, and the fastest way to warm up an engine is to drive.
","text":"This is 100 percent correct.Warm up wears an engine more than just driving it.","replyToPid":5218}
发表于 2019-3-20 00:16:01 来自手机 | 显示全部楼层
{"replyTo":"","text":"Well, I have a rule of thumb that if I'm getting warm air from the HVAC system I'm good to go, most engine wear occurs during a warm-up, and the fastest way to warm up an engine is to drive.","replyToPid":0}
发表于 2019-3-19 04:59:41 来自手机 | 显示全部楼层
{"replyTo":"","text":"In cold weather (35 degrees) 1hrs, in hot weather between 15min & 25min.","replyToPid":0}
发表于 2019-3-19 10:41:34 来自手机 | 显示全部楼层
{"replyTo":"","text":"Usually till oil temp rise to 130* ","replyToPid":0}
发表于 2019-3-20 12:41:05 来自手机 | 显示全部楼层
{"replyTo":"","text":"Isx cm2350 until my oil At least 150 but if it’s really cold I wait until it is up to operating temp at least 200","replyToPid":0}
 楼主| 发表于 2019-3-26 02:04:00 来自手机 | 显示全部楼层
{"replyTo":"","text":"Thanks for your inputs guys!","replyToPid":0}
发表于 2019-3-26 03:42:59 来自手机 | 显示全部楼层
{"replyTo":"","text":"Depends on the engine and set up. 125* on the water. Drive easy till it. Comes all the way up to operating temp","replyToPid":0}
发表于 2019-3-27 16:27:31 来自手机 | 显示全部楼层
{"replyTo":"","text":"With today technology (new engines) you dont have to do it anymore","replyToPid":0}
GMT+8, 2026-2-5 09:08 , Processed in 0.080744 second(s), 24 queries .
