查看: 216|回复: 6
Is excessive axeling really a thing?
 楼主| 发表于 2019-3-15 04:47:14 来自手机 | 显示全部楼层 |阅读模式
{"text":"Is this really a thing? An experienced driver was saying that in Michigan that if you have the tandems slid all the forward they will write you a ticket because MI has a king pin law that requires the tandems to be in a certain range. The only way the load is legal is with them all the way forward?  ","pics":"[]","canComment":true}
发表于 2019-3-15 06:45:25 来自手机 | 显示全部楼层
{"replyTo":"","text":"most states do , its part of the bridge law","replyToPid":0}
发表于 2019-3-15 05:41:02 来自手机 | 显示全部楼层
{"replyTo":"","text":"never heard of it","replyToPid":0}
发表于 2019-3-17 06:40:58 来自手机 | 显示全部楼层
{"replyTo":"","text":"it's funny most people don't know what bridge law is. I have that problem with most drivers on my fleet. there not a issue with tandems being all the way forward. problem is when you have them to the rear pass the legal limit of the state your traveling to.","replyToPid":0}
发表于 2019-3-20 04:40:11 来自手机 | 显示全部楼层
{"replyTo":"","text":"Its always good to learn something new","replyToPid":4994}
发表于 2019-3-20 16:20:38 来自手机 | 显示全部楼层
{"replyTo":"","text":"Same with flatbeds, can’t be pulled together in 3 states Connecticut California and Florida 🤙🏼state law","replyToPid":0}
发表于 2019-3-20 21:29:31 来自手机 | 显示全部楼层
{"replyTo":"","text":"each state is different,  Maryland will give you a ticket if you have your axles pulled all the way forward on a 53' . \n\nMaryland Semi Trailer Truck Weight and Dimension Limits\n\nMaryland has a few additional restrictions on a standard semi-truck that should be taken into consideration. Maryland, like Canadian Provinces has stricter specifications on trailers between 48’ and 53’. In addition to a 41’ kingpin to center of tandems distance, Maryland inforces a 4’ maximum kingpin setback, as well as an effective rear overhang of 35% of the trailer wheelbase. Additionally, Maryland restricts the gross weight of vehicles with less than 5 axles to less than weights allowed by the bridge formula. For container movements, you can apply for a permit for containerized freight that is travelling to and from a port. When hauling a 20’ container on a 40’ container chassis, a permit is available for 90,000 lb gross weight.","replyToPid":0}
GMT+8, 2026-4-17 08:15 , Processed in 0.439030 second(s), 24 queries .
