查看: 105|回复: 6
Bridge law vs kpra
 楼主| 发表于 2019-3-14 04:32:35 来自手机 | 显示全部楼层 |阅读模式
{"text":"I have always heard state tandem setting restrictions referred to as king pin to rear axle, or king pin settings. Bridge law to me is the formula where you can figure out how much you can gross based on number of axles and axle spread.\n\n\nCan the terms be used interchangeably?","pics":"[]","canComment":true}
发表于 2019-3-14 06:45:39 来自手机 | 显示全部楼层
{"replyTo":"","text":"bridge laws have nothing to do with bridges. like Hoppy said, it is so you do not exceed weight rating of the trailer between \"bridged\" axles. this goes for ALL axle bridges unless a multi axle trailer, such as those that have 3 or more axles on the trailer. i have seen trailers have as many as 40 axles (the M1A Abrahms tank hauler)\n\nkingpin to center of last axle is for tight turn radius in certain jurisdictions like CA and certain state routes in various states.","replyToPid":0}
发表于 2019-3-14 06:12:19 来自手机 | 显示全部楼层
{"replyTo":"","text":"when 53's first came out there were problems with trailers breaking in half so the states came up with the bridge law to keep from over loading the gap between the tractor axles and the trailer axles .... that is how a very friendly Florida DOT officer explained it to me one night right before he gave me a ticket for exceeding the FL bridge law","replyToPid":0}
发表于 2019-3-17 18:09:09 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"Everyone relies on gps and phone for trip planning, but if you spend the money and get an actual atlas, in the front they list every state. In each states info is truck restricted roads, bridge law info, etc. I use my atlas all the time. Also, at the end of the day, if you have questions CALL that states Highway Patrol/DOT number. They’ll give you all the info you need. I’ve called Oregon and CA plenty of times. "}
发表于 2019-3-17 12:27:17 来自手机 | 显示全部楼层
630524 发表于 2019-03-13 22:12:19 when 53's first came out there were problems with trailers breaking in half so the states came up with the bridge law to keep from over loading the gap between the tractor axles and the trailer axles .... that is how a very friendly Florida DOT officer explained it to me one night right before he gave me a ticket for exceeding the FL bridge law
","text":"Does each state have different bridge law?","replyToPid":4926}
发表于 2019-3-18 03:30:01 来自手机 | 显示全部楼层
{"replyTo":"","text":"Each state has a different bridge law if they have one as well. The golden rule is if you are legal for ca then you are legal everywhere which is 40 feet from kingpin to middle of rear axle. ","replyToPid":0}
发表于 2019-3-19 01:02:47 来自手机 | 显示全部楼层
{"replyToPid":5073,"replyTo":"
405719 发表于 2019-03-17 04:27:17 Does each state have different bridge law?
","text":"yes they do , as others have said a good map book will give you the different rules of each state and contact numbers for state offices if you need further assistance.  i won't leave home without my map book"}
GMT+8, 2026-2-4 12:37 , Processed in 0.056794 second(s), 24 queries .
