查看: 262|回复: 11
How often do you get to keep food because of damaged package?
 楼主| 发表于 2019-3-13 23:59:54 来自手机 | 显示全部楼层 |阅读模式
{"text":"I don't do a whole lot of reefer, but I got to keep a case of 1 dozen frozen pizzas because the cardboard case was torn up. Any experiences such as this?","pics":"[]","canComment":true}
发表于 2019-3-14 05:44:35 来自手机 | 显示全部楼层
{"replyTo":"","text":"As long as its on the fridge and the taste is not bad at all when you eat it, that's fine.","replyToPid":0}
发表于 2019-3-14 05:52:57 来自手机 | 显示全部楼层
{"replyTo":"","text":"i always had fresh produce when i pulled reefer .... even if there wasn't any damage","replyToPid":0}
发表于 2019-3-14 07:15:19 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"Bout once a month"}
发表于 2019-3-14 08:07:42 来自手机 | 显示全部楼层
{"replyTo":"","text":"Just one of the perks of being a dry van or reefer ","replyToPid":0}
发表于 2019-3-14 11:27:08 来自手机 | 显示全部楼层
{"replyTo":"","text":"lucky you","replyToPid":0}
发表于 2019-3-17 05:12:13 来自手机 | 显示全部楼层
{"replyTo":"","text":"as long as the food itself is good. As often as I can","replyToPid":0}
发表于 2019-3-19 02:22:59 来自手机 | 显示全部楼层
{"replyTo":"","text":"lucky reefer drivers","replyToPid":0}
发表于 2019-3-22 01:38:16 来自手机 | 显示全部楼层
{"replyTo":"","text":"so lucky","replyToPid":0}
发表于 2019-3-26 23:59:19 来自手机 | 显示全部楼层
{"replyTo":"","text":"every few weeks. my freezer at home is full of stuff that got rejected because of a damaged case.","replyToPid":0}
GMT+8, 2026-3-21 06:30 , Processed in 0.108904 second(s), 25 queries .
