查看: 250|回复: 8
Need tips/tricks on passing the blood pressure test
 楼主| 发表于 2019-3-13 04:32:49 来自手机 | 显示全部楼层 |阅读模式
{"text":"I am starting with another company and want to make sure I pass the BP test (last time I was just on the border). Any tips?  ","pics":"[]","canComment":true}
发表于 2019-3-13 08:06:46 来自手机 | 显示全部楼层
{"replyTo":"","text":"Lay off the caffeine and nicotine  24 hrs before the exam. Also, there is a list of fruits and veggies on-line that lower your BP. Load up on some of these the night before, as well. If you can, have them take your urine before they check your BP. Emptying your bladder will also lower your BP somewhat. Don't forget to get plenty of rest the night before the exam. Good luck brother.","replyToPid":0}
发表于 2019-3-14 04:06:04 来自手机 | 显示全部楼层
{"replyTo":"","text":"Everything he says is good advice. I will add. Don’t drink coffee 12 hours before. Drink as much water as you can stand starting 12 hours before. Eat raw almonds  then an hour or two before take about 4 aspirin. Just regular aspirin. Make sure they don’t have caffeine in them. Practice calming breath technique also. ","replyToPid":0}
发表于 2019-3-13 21:42:42 来自手机 | 显示全部楼层
{"replyTo":"","text":"Good luck. ","replyToPid":0}
发表于 2019-3-14 08:23:35 来自手机 | 显示全部楼层
{"replyTo":"","text":"Take a Xanax 2 hours prior ","replyToPid":0}
发表于 2019-3-19 01:54:59 来自手机 | 显示全部楼层
{"replyTo":"","text":"Good luck!","replyToPid":0}
发表于 2019-3-28 07:01:43 来自手机 | 显示全部楼层
{"replyTo":"","text":"Here's a thought! Go see a doctor and get on high blood pressure medication before you kill someone while you're having a heart attack or a stroke behind the wheel. It's easier to have to get a physical every year than having the thought of killing someone. I gladly go every year. 😁","replyToPid":0}
发表于 2019-3-28 23:44:36 来自手机 | 显示全部楼层
{"replyTo":"","text":"You could Smoke a J to keep them doctors away!!😂🌴🔥","replyToPid":0}
发表于 2019-3-31 09:48:25 来自手机 | 显示全部楼层
{"replyTo":"","text":"Cinnamon and magnesium. Take them together and at night. Will lower your blood pressure; cinnamon is also great for blood sugar regulation and magnesium will help you sleep. My mother in law is a naturopath.","replyToPid":0}
GMT+8, 2026-3-21 14:52 , Processed in 0.084495 second(s), 24 queries .
