查看: 355|回复: 13
Home time for OTR drivers question
 楼主| 发表于 2019-3-11 23:23:42 来自手机 | 显示全部楼层 |阅读模式
{"text":"I'm just wondering, I would like to be on the road for 2-3 months without home time, and then take time off. Do the company's line that or not? How much home time can I expect after being on the road for That long?  ","pics":"[]","canComment":true}
发表于 2019-3-12 07:35:16 来自手机 | 显示全部楼层
{"replyTo":"","text":"Companies don't like it, because they have that need their products moved. Don't talk to your dispatcher! Talk to the head of operations manager or owner about that 👍","replyToPid":0}
发表于 2019-4-17 09:48:32 来自手机 | 显示全部楼层
634609 发表于 2019-04-16 14:00:12 LST Express inc. small company at Bakersfield California.
","text":"Ask for an advance on your fuel card. Take the advance and buy an atlas and gps. Alway check gps suggestion against your atlas. Check addresses received from dispatch against Satellite Photos on Google Maps. Make sure it looks like a truck is actually supposed to be there. Call shipper or consignee to confirm locations seen on sat photo or street view if necessary. Never completely trust addresses received or they could send you downtown to a corporate office instead of a DC. Preplan preplan preplan preplan preplan preplan. I don’t care if you have to sit at a truck stop for two hours confirming pickup and delivery locations and follow a satellite photo along every road you plan to drive down. Do it. I’ll do it to make sure I see semis on the road in sat photos. The gps WILL screw you eventual. Never forget to check its work, don’t take it as gospel. If you miss a turn and it recalculates, recheck your gps’s solution, it could have edited your route further ahead. It can and will screw you if you trust it completely. ","replyToPid":14754}
发表于 2019-4-15 16:12:37 来自手机 | 显示全部楼层
{"replyTo":"","text":"Mega fleets give you 1 day off for every 1 week your otr. Minimum of 2wk otr. They usually don’t let you take more than 4 days of if you want to keep your truck. Turn it in and they’ll put someone else in it while your doing whatever. So staying otr longer doesn’t get you more hometime. ","replyToPid":0}
发表于 2019-4-15 16:18:30 来自手机 | 显示全部楼层
634609 发表于 2019-04-15 02:47:43 I'm just  a New driver . What  is the best way going back to Bakersfield CA from  Elloree South Carolina?
","text":"Bro you’re not going to last in trucking. You’re using a smartphone to talk on truckerpath but you don’t have an atlas, aren’t using google maps, hell truckerpath has a routing function but I wouldn’t trust it 100%. Who hired you?","replyToPid":14006}
发表于 2019-3-13 08:25:52 来自手机 | 显示全部楼层
{"replyTo":"","text":"I used to stay out 4 weeks, then take 5 days off as a lease operator. Dispatch didn’t like it, but I did it anyway. But honestly, if you can’t make money only being out 5 1/2 days, being out 4 weeks or more is going to bring any more money. I make more now, being home every weekend than I did when I was out for three or 4 weeks at a time.","replyToPid":0}
发表于 2019-3-13 01:37:25 来自手机 | 显示全部楼层
544240 发表于 2019-03-11 23:35:16 Companies don't like it, because they have that need their products moved. Don't talk to your dispatcher! Talk to the head of operations manager or owner about that 👍
","text":"So this is something that should be raised to a manager directly. hmm","replyToPid":4781}
发表于 2019-3-12 11:12:22 来自手机 | 显示全部楼层
{"replyTo":"","text":"Firstly, what's the longest duration you've been on the road so far?","replyToPid":0}
发表于 2019-3-28 04:02:20 来自手机 | 显示全部楼层
{"replyTo":"","text":"I drive for CFI and stay out about 2 to 3 months then go home for about a week or more. We don't lose the days we build up and take as much time off as we want and keep our trucks. With at least 8 days notice you will almost always be home on the day you request.","replyToPid":0}
发表于 2019-3-28 07:15:17 来自手机 | 显示全部楼层
{"replyTo":"","text":"Good luck with that. I used to drive for a company that would keep me out for 2 months at a time then allow me only a 34 hour restart when they finally decided to to get me home.","replyToPid":0}
发表于 2019-4-15 06:54:51 来自手机 | 显示全部楼层
{"replyTo":"","text":"I used to be out for 4 to 6 weeks. then 4 days home, But now 5 yrs. later I go out no longer than 10 days and can take 2-3 days off and make more  money.","replyToPid":0}
发表于 2019-4-15 10:47:43 来自手机 | 显示全部楼层
{"replyTo":"","text":"I'm just  a New driver . What  is the best way going back to Bakersfield CA from  Elloree South Carolina?","replyToPid":0}
GMT+8, 2026-4-17 18:04 , Processed in 0.672489 second(s), 24 queries .
