查看: 248|回复: 8
How do I know how much I am making? Paid vs. Unpaid miles
 楼主| 发表于 2019-3-7 23:35:09 来自手机 | 显示全部楼层 |阅读模式
{"text":"How do I know what I am actually making? Currently, carrier pays .43cpm but only for loaded miles. How do I factor in the MT miles I have to drive so see what I'm actually earning per mile?","pics":"[]","canComment":true}
发表于 2019-3-28 07:54:14 来自手机 | 显示全部楼层
251702 发表于 2019-03-27 20:13:38 Go to a company that pays for loaded and empty miles. In the meantime keep track of your unpaid miles. You will see the difference. You are getting cheated.
","text":"Go find a company that pays empty miles. You're getting screwed.","replyToPid":6157}
发表于 2019-3-28 04:13:38 来自手机 | 显示全部楼层
{"replyTo":"","text":"Go to a company that pays for loaded and empty miles. In the meantime keep track of your unpaid miles. You will see the difference. You are getting cheated.","replyToPid":0}
发表于 2019-3-8 00:49:23 来自手机 | 显示全部楼层
{"replyTo":"","text":"Total miles for paycheck, then divide ➗ the gross of the paycheck = 💩😂","replyToPid":0}
发表于 2019-3-28 07:55:35 来自手机 | 显示全部楼层
","text":"Sorry Big Scott. Obviously that wasn't meant for you. lol","replyToPid":6157}
发表于 2019-3-31 11:28:00 来自手机 | 显示全部楼层
{"replyTo":"","text":"Big Scott is right. Keep track of your unpaid miles.  Do the math and see what you are really earning.  I work for a company that pays the same loaded and unloaded and I’m still only making $14.00/hr at the end of the day (3 months of data).  ...and yes, I am looking for a new employer but I need more experience before I can apply ay many of the jobs I see out there.","replyToPid":0}
发表于 2019-4-15 06:46:32 来自手机 | 显示全部楼层
{"replyTo":"","text":"find a new company that pays you actual miles from the odometer, That company is STEALING from you, You should not work for free loaded or empty you have the same driving responsibilities empty or loaded.","replyToPid":0}
发表于 2019-4-15 22:11:38 来自手机 | 显示全部楼层
{"replyTo":"","text":"Look get with someone who pays loaded and unloaded and look for a better pay rate .. if you are a good solid driver and not fresh out of so called cal school you should have no trouble finding a better rate . Get away from that rate","replyToPid":0}
发表于 2019-4-15 22:12:37 来自手机 | 显示全部楼层
{"replyTo":"","text":"Look get with someone who pays loaded and unloaded and look for a better pay rate .. if you are a good solid driver and not fresh out of so called cdl school you should have no trouble finding a better rate . Get away from that rate","replyToPid":0}
GMT+8, 2026-4-19 18:52 , Processed in 0.101462 second(s), 24 queries .
