查看: 120|回复: 4
APU recommendations?
 楼主| 发表于 2019-3-5 00:04:04 来自手机 | 显示全部楼层 |阅读模式
{"text":"Looking into APU's. Would prefer to buy new, with a good warranty. Any recommendations? And is it gonna be costly for maintenance? Thanks.  ","pics":"[]","canComment":true}
发表于 2019-3-5 08:12:33 来自手机 | 显示全部楼层
{"replyTo":"","text":"Carrier. New between $10,000 & $12,000.  If you do the maintenance with carrier will be costly. You can do Maintanance by your self is easy.","replyToPid":0}
发表于 2019-3-6 01:02:26 来自手机 | 显示全部楼层
{"replyTo":"","text":"You have to call around. Sometimes they put them on sale for 8K-10K.  I have had a thermo king and a older RigMaster. I like having them. ","replyToPid":0}
发表于 2019-3-27 14:15:21 来自手机 | 显示全部楼层
{"replyTo":"","text":"Check battery operated apu’s. The latest models can work and provide cold air for 12 hours on a 100f sunny day easily. In the winter they don’t overheat and overdry air in the sleeper. They will also keep coolant warm. If properly installed the apu will send a signal and start the truck engine when batteries drain below a certain voltage and stop it in a few hours when batteries recharge. They are quite, don’t vibrate and a lot cheaper to maintain. Also they cost 4-7k vs 10-12k for diesel operated apu","replyToPid":0}
发表于 2019-3-30 14:18:38 来自手机 | 显示全部楼层
{"replyTo":"","text":"Mine is a comfort pro been a pretty good one. ","replyToPid":0}
GMT+8, 2026-2-5 07:36 , Processed in 0.076282 second(s), 23 queries .
