查看: 423|回复: 7
How to become an Owner/Operator checklist?
 楼主| 发表于 2019-3-5 00:03:15 来自手机 | 显示全部楼层 |阅读模式
{"text":"Is there a checklist somewhere on the web with all the steps, in order, for becoming an O/O? Tried Google but my search skills aren't that good.  ","pics":"[]","canComment":true}
发表于 2019-3-5 02:42:46 来自手机 | 显示全部楼层
{"replyTo":"","text":"check with your state mine had a packet of all the paper work needed and join a organization like ooida. they will help you along with what is needed. and be aware when you get your dot and mc numbers you will be getting emails and phone calls from companys that will process your numbers which you have to do but they will charge you 1000 plus to do it. I joined Maine motor transportation Association where I am from Maine and they only charged me $25. there is a lot of paperwork a lot of running around that you will have to do just be patient be aware of all the BS and good luck","replyToPid":0}
 楼主| 发表于 2019-3-5 04:24:23 来自手机 | 显示全部楼层
289718 发表于 2019-03-04 18:42:46 check with your state mine had a packet of all the paper work needed and join a organization like ooida. they will help you along with what is needed. and be aware when you get your dot and mc numbers you will be getting emails and phone calls from companys that will process your numbers which you have to do but they will charge you 1000 plus to do it. I joined Maine motor transportation Association where I am from Maine and they only charged me $25. there is a lot of paperwork a lot of running around that you will have to do just be patient be aware of all the BS and good luck
","text":"Thanks for this. You are a life saver.","replyToPid":4221}
发表于 2019-3-6 10:03:46 来自手机 | 显示全部楼层
{"replyTo":"","text":"There's no checklist to becoming an owner operator. There's a checklist of things you need to do operate as a carrier. It's a lot going on as far as being a owner operator. There's not a list cuz there's so many directions you can start from as to being a owner operator. There is a checklist for all the things you need to operate as a carrier.","replyToPid":0}
发表于 2019-3-28 11:08:14 来自手机 | 显示全部楼层
{"replyTo":"","text":"Would anyone recommend trying a LP program before going O/O to get an idea of what it will be like to be an O/O?","replyToPid":0}
发表于 2019-3-31 23:30:23 来自手机 | 显示全部楼层
{"replyTo":"","text":"1 - cash","replyToPid":0}
发表于 2019-5-2 13:29:34 来自手机 | 显示全部楼层
118257 发表于 2019-03-28 03:08:14 Would anyone recommend trying a LP program before going O/O to get an idea of what it will be like to be an O/O?
","text":"Yes but I’ve found only 1 honest LP- Brite logistics Inc in Chicago","replyToPid":6332}
发表于 2019-5-2 13:31:28 来自手机 | 显示全部楼层
","text":"Yes but I’ve found only 1 honest LP- Brite logistics in chicago","replyToPid":6332}
GMT+8, 2026-4-15 12:04 , Processed in 3.382511 second(s), 24 queries .
