请选择 进入手机版 | 继续访问电脑版
查看: 622|回复: 17
Personal Conveyance question
 楼主| 发表于 2019-3-1 05:02:47 来自手机 | 显示全部楼层 |阅读模式
{"text":"I am in the middle of my 34 now and was looking to do some shopping and maybe catch a movie but the nearest of either of is is 40 miles away in the direction my load is going. Since PC doesn't allow us to further with Our load. Am I just out of luck?","pics":"[]","canComment":true}
发表于 2019-3-1 07:10:27 来自手机 | 显示全部楼层
{"replyTo":"","text":"You can drive your truck and trailer there, but you have to go back to the point where you started the personal conveyance. That's the rule 👍","replyToPid":0}
回复 支持 10 反对 1
发表于 2019-4-25 05:28:29 来自手机 | 显示全部楼层
{"replyTo":"","text":"Based on the “guidance”, you cannot operate a vehicle on Personal Conveyance in the following situations:\n- To further your location towards a pick up.\n- To extend your clock \n- Within 10 hrs of a pick up or delivery.\n- To perform any business related function,  fueling, maintenance, etc...\n- to return to the point of dispatch.\n\nNow... for the interpretation of this rules hire a Lawyer. lol","replyToPid":0}
发表于 2019-3-1 06:41:56 来自手机 | 显示全部楼层
{"replyTo":"","text":"uber or Lyft try it","replyToPid":0}
发表于 2019-4-20 03:14:16 来自手机 | 显示全部楼层
95010 发表于 2019-03-06 00:53:51 You're out of luck. 40 miles is to far for PC.
","text":"There is no limit unless your company applies one to it.","replyToPid":4370}
发表于 2019-3-6 08:53:51 来自手机 | 显示全部楼层
{"replyTo":"","text":"You're out of luck. 40 miles is to far for PC.","replyToPid":0}
回复 支持 0 反对 3
发表于 2019-4-26 01:00:21 来自手机 | 显示全部楼层
发表于 2019-4-26 01:03:52 来自手机 | 显示全部楼层
95010 发表于 2019-04-25 16:39:35 Some of y'all are trying to abuse the personal conveyance. They will probably change the rule cuz y'all out here trying to do the most. PC is made for going to take a dump and y'all out here trying to travel across the country. There's no excuse to say you needed to drive 40 miles from a shipper or receiver to take a dump or get dinner. Y'all setting yourselves up for failure.
","text":"Rules say you still have to run within reason. If you are pulled and determined to be fatigued you will pe shut down.","replyToPid":21015}
发表于 2019-4-26 00:46:40 来自手机 | 显示全部楼层
586943 发表于 2019-04-25 16:36:42 It’s not just for food... sometimes there is no parking for that far....
","text":"😂😂😂🤣🤣 No parking? The truck stop isn't the only place to park a truck. Think outside the box. You'll start to like the world more when you do. There's better food options beyond the truckstop. And better quality of life.","replyToPid":21013}
发表于 2019-3-6 08:56:44 来自手机 | 显示全部楼层
{"replyTo":"","text":"That's 80 miles of traveling if you have to go back where you started.","replyToPid":0}
发表于 2019-3-2 22:42:03 来自手机 | 显示全部楼层
{"replyTo":"","text":"Good rule of thumb when loaded....\"where you end is where you begin\". When headed home there is some options but not to a drop yard. It's convoluted and confusing on purpose. Obviously. Your tax dollars at work.","replyToPid":0}
发表于 2019-3-1 06:07:25 来自手机 | 显示全部楼层
{"replyTo":"","text":"if you can drop your trailer Bobtail you would be fine","replyToPid":0}
发表于 2019-4-26 00:01:31 来自手机 | 显示全部楼层
610123 发表于 2019-04-19 19:14:16 There is no limit unless your company applies one to it.
","text":"Yes your correct but you guys are missing the point. Why would you take an hr from yourself on the log to go get food? If you were going home for a 34hr break it wouldn't matter. I guess most people who will drive 80 miles for food isn't paying for their own fuel either. 40 miles for food is not that serious. People should be better prepared. Carry PB&J or have something to snack on to prevent cutting 1.5hrs from your potential pay.","replyToPid":16873}
GMT+8, 2026-4-18 21:29 , Processed in 0.105136 second(s), 24 queries .
