查看: 350|回复: 6
How long will this “low-rate season” going to last?
 楼主| 发表于 2019-3-1 05:01:36 来自手机 | 显示全部楼层 |阅读模式
{"text":"How long will this season of horribly low-rates last? Any thoughts?","pics":"[]","canComment":true}
发表于 2019-3-26 08:02:45 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"Low rates are a normal part of the freight economy. There will be times the freight will pay very well in some states, and very low in others. My recommendation is to haul freight only in the regions where freight is paying well. Currently this means staying away from FL and CA, to name two. DAT publishes inbound/outload load ratios per state. They do charge for this. FL has lots of inbound freight and low outbound freight most of the year, which translates to cheap freight going out. It’s economics at play. "}
发表于 2019-3-6 08:10:30 来自手机 | 显示全部楼层
{"replyTo":"","text":"forget brokers and find direct shippers.","replyToPid":0}
发表于 2019-3-1 20:07:21 来自手机 | 显示全部楼层
{"replyTo":"","text":"If you are experiencing low rates find a new broker.","replyToPid":0}
发表于 2019-3-1 06:09:36 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"I think March is the last month. Usually this pick up in my company by April "}
发表于 2019-3-1 12:02:23 来自手机 | 显示全部楼层
{"replyTo":"","text":"A lot of it has to do with MSM’s fake news 👎👎","replyToPid":0}
发表于 2019-3-30 01:56:05 来自手机 | 显示全部楼层
{"replyTo":"","text":"Truckers shutdown is coming... 😆","replyToPid":0}
GMT+8, 2026-4-15 12:03 , Processed in 0.167461 second(s), 24 queries .
