查看: 262|回复: 4
Moving to Schneider. What is it like?
 楼主| 发表于 2019-2-28 23:57:50 来自手机 | 显示全部楼层 |阅读模式
{"text":"I'm moving from swift to Schneider. Regional part-time. \n\n\nWhat's their orientation like? And what's the difference between the two companies if you have worked for both.","pics":"[]","canComment":true}
发表于 2019-3-1 17:02:19 来自手机 | 显示全部楼层
{"replyTo":"","text":"I’ve worked for both. Schneider is better organized and more efficient with better company wide communication than Swift. Plus they pay more than Swift does. And their facilities are much cleaner and more accommodating, including a gym and actual real showers instead of disgusting stalls. The only real downside I see right now is with Schneider you’ll have less choice of truck. They only run Freightliners unless you’re a team or owner operator. ","replyToPid":0}
发表于 2019-3-1 17:03:55 来自手机 | 显示全部楼层
{"replyTo":"","text":"Also the mechanics at Schneider will actually fix your dang truck instead of standing around doing nothing and lying about it like they do at Swift. It’s just a better company. ","replyToPid":0}
发表于 2019-4-5 22:30:38 来自手机 | 显示全部楼层
{"replyTo":"","text":"Do you have any info about Schneider local driving poison?","replyToPid":0}
发表于 2019-5-10 09:14:35 来自手机 | 显示全部楼层
{"replyTo":"","text":"neither to show of trucks","replyToPid":0}
GMT+8, 2026-4-17 07:30 , Processed in 0.088156 second(s), 24 queries .
