查看: 168|回复: 3
SAIA driver cam question
 楼主| 发表于 2019-2-28 23:55:26 来自手机 | 显示全部楼层 |阅读模式
{"text":"I assume that the camera system records things like following too closely, hard braking etc.\n\n\nI’m curious as to what the algorithm for following too closely is. Something like 3-second following distance at 55mph+ for 3 minutes or a variant of that?","pics":"[]","canComment":true}
发表于 2019-3-28 04:17:43 来自手机 | 显示全部楼层
512094 发表于 2019-02-28 17:28:53 I used to work for them the camera will give you a warning so you can back off if you don’t it starts recording. I have had 2 jobs with forward facing and into the cab facing camera. I quit both and will never drive for another company that uses them. I cannot drive facing forward all day, not drinking from my water bottle, or talking on the phone I use earbuds. I have been written up for all of those. Saia is one of the worst companies I have ever worked for.
","text":"It's illegal to drive with earbuds or headphones in/on both ears.","replyToPid":3913}
发表于 2019-3-1 01:28:53 来自手机 | 显示全部楼层
{"replyTo":"","text":"I used to work for them the camera will give you a warning so you can back off if you don’t it starts recording. I have had 2 jobs with forward facing and into the cab facing camera. I quit both and will never drive for another company that uses them. I cannot drive facing forward all day, not drinking from my water bottle, or talking on the phone I use earbuds. I have been written up for all of those. Saia is one of the worst companies I have ever worked for.","replyToPid":0}
发表于 2019-4-15 00:05:58 来自手机 | 显示全部楼层
","text":"Whelllo","replyToPid":3913}
GMT+8, 2026-4-17 16:37 , Processed in 0.075163 second(s), 25 queries .
