查看: 434|回复: 3
CRST is just BAD!
 楼主| 发表于 2019-2-28 03:52:44 来自手机 | 显示全部楼层 |阅读模式
{"text":"What companies will hire me even if I’m on contract to crst? They are the worst company ever. My hr department said I’m not under the non compete clause, but I’ve been turned down by two different companies already. Should I just not say I work at crst?","pics":"[]","canComment":true}
发表于 2019-3-26 01:52:05 来自手机 | 显示全部楼层
{"replyTo":"","text":"If CRST trained you read your contract. They are serious about their non compete clause until you pay them. Very few companies will touch you.","replyToPid":0}
发表于 2019-3-26 00:51:45 来自手机 | 显示全部楼层
{"replyTo":"","text":"I was with Malone for a little while, are you sure those two companies that turned you down are not subsidiaries of CRST? CRST is kind of like saying Swift or JB Hunt or Warner etc. just keep putting in applications with different companies you'll find another job. as a matter of fact might want to try Martin Transportation Services","replyToPid":0}
发表于 2019-5-4 01:00:06 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"try Crete/Shaffer\nMy s/o started with CRST and they were willing to take him under the clause (if there actually happens to be one for you)"}
GMT+8, 2026-4-17 21:53 , Processed in 0.098167 second(s), 24 queries .
