查看: 222|回复: 6
Spread Axle Inquiry
 楼主| 发表于 2019-2-26 05:35:55 来自手机 | 显示全部楼层 |阅读模式
{"text":"Looking at buying a 48 flatbed spread axle. Wondering what the pros and cons were and what your preference is.","pics":"[]","canComment":true}
发表于 2019-2-26 07:34:37 来自手机 | 显示全部楼层
{"replyTo":"","text":"I pulled an all aluminum 48x102 with a 10/2 spread. Had two boxes between the spread axles and a dump air switch in the cab. You for sure want to be able to dump the air bags when backing and sharp turns.","replyToPid":0}
发表于 2019-2-27 03:12:03 来自手机 | 显示全部楼层
{"replyTo":"","text":"I would recommend not putting the boxes between the axles for the simple reason if you blow a tire and yes a virgin tire does blow. If you put them there and a tire blows those pricey boxes are now destroyed. I would mount them closer to the front or in the center.","replyToPid":0}
 楼主| 发表于 2019-3-5 01:07:24 来自手机 | 显示全部楼层
{"replyTo":"","text":"thanks for your input guys!","replyToPid":0}
发表于 2019-3-5 10:11:54 来自手机 | 显示全部楼层
618572 发表于 2019-02-25 23:34:37 I pulled an all aluminum 48x102 with a 10/2 spread. Had two boxes between the spread axles and a dump air switch in the cab. You for sure want to be able to dump the air bags when backing and sharp turns.
","text":"48' Is To Short\nUnless your moving \nCoils\nDon't waste your money","replyToPid":3603}
发表于 2019-3-6 07:30:36 来自手机 | 显示全部楼层
{"replyTo":"","text":"i pull a frameless end dump with a 2-10 spread.  must have a dump on back axle for tight turns and backing up , they can be hard on tires but they ride good","replyToPid":0}
发表于 2019-3-9 09:46:38 来自手机 | 显示全部楼层
{"replyTo":"","text":"I’d get a 53’, not a 48’","replyToPid":0}
GMT+8, 2026-4-17 19:54 , Processed in 0.100020 second(s), 24 queries .
