查看: 167|回复: 5
is there a way to see eta when tapping on random truck stops before adding to to route??
 楼主| 发表于 2026-2-16 05:29:36 来自手机 | 显示全部楼层 |阅读模式
{"text":"I just started driving so I thought this app would be good for trip planning","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2026-2-18 00:20:14 来自手机 | 显示全部楼层
{"replyTo":"","text":"Listen. If you click on the truck stop, the app does calculate the miles that you currently are from that truck truckstop. So just take your MPH and figure out the time that way. That is what I usually do too.","replyToPid":0}
发表于 2026-2-16 06:46:56 来自手机 | 显示全部楼层
{"replyTo":"","text":"No. You can only see the distance, and based on that you can have some idea of the ETA.","replyToPid":0}
发表于 2026-2-19 08:32:35 来自手机 | 显示全部楼层
{"replyTo":"","text":"Divide the mile by your speed it’s the only I can do it. Wish they would add the option","replyToPid":0}
发表于 2026-2-18 00:18:47 来自手机 | 显示全部楼层
{"replyTo":"","text":"I use my extra tablet for this main issue. Lol. I know exactly where you’re coming from. The struggle is very real.","replyToPid":0}
发表于 2026-2-22 04:14:29 来自手机 | 显示全部楼层
{"replyTo":"","text":"The only way is to add it to the route as next stop if you don’t like the eta just hit the x next to that added stop and keep searching","replyToPid":0}
GMT+8, 2026-3-21 21:04 , Processed in 0.054573 second(s), 24 queries .
