查看: 215|回复: 7
Shippers refuse to load dry freight in reefers. Why?
 楼主| 发表于 2019-2-26 05:32:34 来自手机 | 显示全部楼层 |阅读模式
{"text":"I see on some loads posted where they say van only even when the load is light.","pics":"[]","canComment":true}
发表于 2019-2-26 21:09:54 来自手机 | 显示全部楼层
{"replyTo":"","text":"After spending some time thinking about it. It dawned on me. Reefers are smaller on the inside then dry vans do too wall thickness. They are shorter and not as wide. If a customer loads pallets sideways and double stacked to fit as much freight on one load as possible then they need more room to do so.  #now_weknow","replyToPid":0}
发表于 2019-2-26 05:39:55 来自手机 | 显示全部楼层
{"replyTo":"","text":"No one knows. ","replyToPid":0}
发表于 2019-2-28 11:47:39 来自手机 | 显示全部楼层
{"replyTo":"","text":"Interior dimensions are narrower than a dry van.","replyToPid":0}
发表于 2019-3-2 03:53:02 来自手机 | 显示全部楼层
{"replyTo":"","text":"also they have cant load as much because of the extra weight of the reefer unit","replyToPid":0}
 楼主| 发表于 2019-3-2 06:37:45 来自手机 | 显示全部楼层
{"replyTo":"","text":"Thanks for your input guys!","replyToPid":0}
发表于 2019-3-8 09:57:09 来自手机 | 显示全部楼层
{"replyTo":"","text":"never had that problem","replyToPid":0}
发表于 2019-3-8 12:32:54 来自手机 | 显示全部楼层
{"replyTo":"","text":"Issues with tall freight also, there's a potential to tear the chute.","replyToPid":0}
GMT+8, 2026-3-21 10:08 , Processed in 0.072680 second(s), 24 queries .
