查看: 179|回复: 6
Protecting Tarps Question
 楼主| 发表于 2019-2-22 21:37:20 来自手机 | 显示全部楼层 |阅读模式
{"text":"How do you protect your tarps from rips?","pics":"[]","canComment":true}
发表于 2019-2-23 06:13:48 来自手机 | 显示全部楼层
{"replyTo":"","text":"Extra cushions made of old strap strips or old tarp. For metal, normally use a blanket style padding to cocer sharp edges.","replyToPid":0}
发表于 2019-2-23 23:30:33 来自手机 | 显示全部楼层
{"replyTo":"","text":"some people used carpet pieces rubber mats like traction pads the main idea is to create a barrier between tarp and anything sharp, pointy, or abrasive. if you can stay the padding to particular corner or edge, some how did it in place to prevent slipping or falling off of edge is ideal.","replyToPid":0}
发表于 2019-3-1 04:04:06 来自手机 | 显示全部楼层
{"replyTo":"","text":"I use moving blankets. Got 15 of em on eBay for like $100 ","replyToPid":0}
发表于 2019-3-2 22:25:22 来自手机 | 显示全部楼层
{"replyTo":"","text":"I agree with moving blankets. Just remember that draping a blanket in place won't always cut it. Tape or rope can be used to insure the blanket stays in place.","replyToPid":0}
 楼主| 发表于 2019-3-5 00:23:56 来自手机 | 显示全部楼层
{"replyTo":"","text":"will check on all of those. thank you guys!","replyToPid":0}
发表于 2019-3-5 06:04:36 来自手机 | 显示全部楼层
{"replyTo":"","text":"Harbor Freight sales heavy duty moving blankets I've use them for some time now when I haul Steel I will tuck it underneath my front strap and my back strap to keep it in place and cover the front in the back of a load and if there is a height difference to","replyToPid":0}
GMT+8, 2026-4-17 19:54 , Processed in 0.093041 second(s), 24 queries .
