查看: 167|回复: 4
lumber tarp and steel tarp.
 楼主| 发表于 2019-2-21 21:37:20 来自手机 | 显示全部楼层 |阅读模式
{"text":"What is the difference between the two? And what do you use? Thanks in advance.","pics":"[]","canComment":true}
发表于 2019-2-22 02:29:18 来自手机 | 显示全部楼层
{"replyTo":"","text":"The main difference is size and weight. Your lumber tarps are going to be bigger both being wider and probably longer than your steel tarp. The lumber tarps are usually always also have a flap on the front that can be pulled down which allows them to cover higher, longer loads. Steel tarps are made to cover loads that aren't dimensionally equivalent to the size of most lumber loads. There are a number of great YouTube videos showing you how to properly put on both types of tarps as well as how to use bungees and ropes to secure them. The best technique however is to just watch other people do it and ask questions.","replyToPid":0}
发表于 2019-2-22 08:44:47 来自手机 | 显示全部楼层
{"replyTo":"","text":"the previously guy said correct. i have lumber tarps and they are made to cover 8' tall.","replyToPid":0}
发表于 2019-3-1 04:07:10 来自手机 | 显示全部楼层
{"replyTo":"","text":"Lumber tarps usually 8 foot drops. Steel usually 4. Best money I ever spent was buying 6 foot drops. They’re all I carry now. ","replyToPid":0}
 楼主| 发表于 2019-3-2 04:47:03 来自手机 | 显示全部楼层
{"replyTo":"","text":"Got it. Thanks!","replyToPid":0}
GMT+8, 2026-4-17 19:54 , Processed in 0.078109 second(s), 24 queries .
