查看: 359|回复: 0
Critical Things Every Trucker Should Be Watching
 楼主| 发表于 2019-2-20 21:52:35 来自手机 | 显示全部楼层 |阅读模式
{"text":"There are some highly critical things that a professional truck driver should be watching for\r\nWhen. Driving a big rig is an important job - It takes the driver’s full attention to do it safely.\r\n\r\nTRUCK DRIVING SAFETY ADVICE\r\n\r\nLook ahead.\r\nAlways look as far ahead down the road as you possibly can. Try to anticipate\r\ntrouble. Watch for cars going sideways, merging onto the highway from ramps, and\r\nanything unusual going on. Always keep in mind, that whatever is ahead on the road, is a\r\npotential problem to deal with.\r\n\r\nLook for an escape route.\r\nWhen driving, Always look for an escape route from any potential trouble. Keep a constant visual check all around the vehicle. Keep your eye on everything going on around you. Then, when necessary, you’re aware of an escape route if needed.\r\n\r\nCheck your mirrors often. \r\nAlways be aware of what’s going on all around the vehicle. Check the blind spots. Truckers should be constantly checking their mirrors to keep an eye on the traffic around them. Also, keep a close eye on the trailer. Keep an eye out for a flat tire or smoke emerging from underneath the trailer.\r\n\r\nScan all gauges.\r\nThe gauges are indicators of potential mechanical trouble. Sometimes the simplest things can cause big problems. Check your fuel level and that electrical systems are charging. Check for overheating. Some trucking companies cut costs by eliminating the extra gauges, which is not a good idea. The gauges are not only indicators and monitors of various truck functions but they are also safety monitors.\r\n\r\nDriving a truck is a huge responsibility. Truckers should be at their best at all times\r\nbehind the wheel, and keep a sharp eye on their surroundings.\r\n","pics":"[{\"description\":\"\",\"height\":640.0,\"name\":\"980/android_1550670735100.jpg\",\"url\":\"\",\"width\":960.0}]","canComment":true}
GMT+8, 2026-2-14 17:40 , Processed in 0.056752 second(s), 23 queries .
