查看: 214|回复: 15
Just for fun: Which Cup Will be Filled First
 楼主| 发表于 2019-2-16 06:16:18 来自手机 | 显示全部楼层 |阅读模式
{"text":"Let’s test your minds.","pics":"[{\"description\":\"\",\"height\":476.0,\"name\":\"172/android_1550268961660.png\",\"url\":\"\",\"width\":494.0}]","canComment":true}
发表于 2019-2-17 14:18:32 来自手机 | 显示全部楼层
{"replyTo":"","text":"5 all the rest are cut off at some point","replyToPid":0}
管理员
Rank: 9Rank: 9Rank: 9
发表于 2019-2-18 06:27:22 来自手机 | 显示全部楼层
{"replyTo":"","text":"Defiantly should be 4","replyToPid":3371}
发表于 2019-2-19 12:08:10 来自手机 | 显示全部楼层
{"replyTo":"","text":"cup 7 for sure!","replyToPid":0}
发表于 2019-10-12 22:58:48 来自手机 | 显示全部楼层
620311 发表于 2019-02-17 06:18:32 5 all the rest are cut off at some point
","text":"that would be cup 9","replyToPid":3369}
发表于 2019-2-22 08:54:57 来自手机 | 显示全部楼层
{"replyTo":"","text":"Oh my gosh, you’re right! The answer is cup # 5. I can’t believe I overlooked that. I don’t see any racist or religious bigotry implications and hope this forum is moderated well enough so as not to be poisoned with such, but good eye on the puzzle. ","replyToPid":0}
发表于 2019-2-21 00:41:54 来自手机 | 显示全部楼层
{"replyTo":"","text":"4 is blocked at the square \n9 is blocked at the cup\n7 is blocked at the elbow \nThat leaves 5 as the only one that is unblocked and able to be filled\nSomeone disliked my answer because of my name. SMH can’t shake racism or religious bigotry no matter what.\n","replyToPid":0}
发表于 2019-2-20 03:58:31 来自手机 | 显示全部楼层
{"replyTo":"","text":"9","replyToPid":0}
发表于 2019-2-18 09:32:14 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"I thought it was 4 at first too, but upon closer examination, I found how the box hanging above the #4 cup is walled off. Look at the bottom left. See how spigot is walled off? Cups 4 and 7 will never be filled as they’re blocked off. "}
发表于 2019-2-18 03:41:54 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"#9"}
发表于 2019-3-8 11:21:37 来自手机 | 显示全部楼层
497499 发表于 2019-02-22 00:54:57 Oh my gosh, you’re right! The answer is cup # 5. I can’t believe I overlooked that. I don’t see any racist or religious bigotry implications and hope this forum is moderated well enough so as not to be poisoned with such, but good eye on the puzzle.
","text":"Thanks","replyToPid":3500}
GMT+8, 2026-2-15 01:24 , Processed in 0.061901 second(s), 24 queries .
