查看: 55|回复: 0
2007 335 transmission oil cooler replacement
 楼主| 发表于 2019-2-12 11:31:07 来自手机 | 显示全部楼层 |阅读模式
{"text":"My Oil cooler has started to rust out and drip coolant. Bought a used one and Im planning to put it in this weekend. Im wondering if there is anything I need to worry about as Ill be disconnecting the large tranny lines and coolant lines. \n\nIs there a special procedure to refilling either of these to avoid air pockets? Anything I should be aware of doing this job?\n\nThanks, \nGaryG","pics":"[]","canComment":true}
GMT+8, 2026-2-4 12:40 , Processed in 0.057796 second(s), 23 queries .
