查看: 187|回复: 1
How to check the gear train timing without taking the gear train cover? Detroit ser 60 14L DDEC V.
 楼主| 发表于 2019-2-12 11:22:12 来自手机 | 显示全部楼层 |阅读模式
{"text":"If you know how to use it absolutely. What it does is measure the lift on the injector lobe of the camshaft when the cylinder is at TDC. The book will have a spec to tell you what it should be. ","pics":"[]","canComment":true}
发表于 2019-4-18 16:39:07 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"Im confused on your Question are asking? what thickness gauge to use or tool used for Height. Im sure by now you already ran the rack after seeing how old the post is."}
GMT+8, 2026-4-17 08:04 , Processed in 0.158788 second(s), 23 queries .
