查看: 91|回复: 9
Route to Philly Question
 楼主| 发表于 2019-2-7 23:19:21 来自手机 | 显示全部楼层 |阅读模式
{"text":"Hello fellow truckers, need you advice on picking a route from Cleveland to Philly. I-76 through PA is a pain in the butt. It's not terrible during daytime, but at night every 4 wheeler on the road has their crazy-bright high beams on. And all those hills & curves just get on my nerves after a few hours. Any other options that take about the same amount of time, give or take 2 hours?\r\n","pics":"[]","canComment":true}
发表于 2019-2-8 05:13:31 来自手机 | 显示全部楼层
{"replyTo":"","text":"You can try I-80 east to I-476 south. Its bout 30 minutes/18 miles longer.","replyToPid":0}
 楼主| 发表于 2019-2-8 22:36:45 来自手机 | 显示全部楼层
{"replyTo":"","text":"Thanks","replyToPid":0}
发表于 2019-2-9 02:09:44 来自手机 | 显示全部楼层
{"replyTo":"","text":"You can run 80 until State College, come down US 322 to Harrisburg. Then 15 to US 30 on in seeking out US 1 through the woods on the PA side of border. Run US 1 until Kennets Square and work your way into philly. Make sure you come through the 95 Naval Yard bridge side near the old stadium on the west side. DO NOT go off 95 into central, NE most especially NOR cross into Camden NJ.","replyToPid":0}
 楼主| 发表于 2019-2-11 20:38:16 来自手机 | 显示全部楼层
{"replyTo":"","text":"Will keep in mind. Thanks","replyToPid":0}
发表于 2019-2-11 22:45:25 来自手机 | 显示全部楼层
{"replyTo":"","text":"you just dont want to pay the tolls","replyToPid":0}
 楼主| 发表于 2019-2-11 23:23:07 来自手机 | 显示全部楼层
{"replyTo":"","text":"Yes. The toll prices are just nuts.","replyToPid":0}
发表于 2019-2-11 23:27:51 来自手机 | 显示全部楼层
{"replyTo":"","text":"I would run 80 to exit 123 pa970 south to 322 east follow all the way to Harrisburg, 283 to 30 to 202 and into Philadelphia. The hell with pa's ridiculous toll rates.","replyToPid":0}
发表于 2019-2-13 03:07:00 来自手机 | 显示全部楼层
{"replyTo":"","text":"Following this thread.","replyToPid":0}
 楼主| 发表于 2019-2-13 03:12:13 来自手机 | 显示全部楼层
{"replyTo":"","text":"Thanks for the advice guys!","replyToPid":0}
GMT+8, 2026-2-4 12:39 , Processed in 0.055939 second(s), 23 queries .
