查看: 328|回复: 5
Freightliner Fridge Issue
 楼主| 发表于 2019-2-7 22:55:06 来自手机 | 显示全部楼层 |阅读模式
{"text":"How long do Freightliner fridges usually last? Mine is only a year old and shut off after being parked a day. Freezer started cooling when I started truck up so Im hoping it starts cooling.","pics":"[]","canComment":true}
发表于 2019-2-9 02:25:10 来自手机 | 显示全部楼层
{"replyTo":"","text":"Have you checked the your electrical draw and load test your batteries? It sounds like the battery protection relay kicked in and shut all non important equipment down because your battery voltage is way to low.","replyToPid":0}
发表于 2019-2-8 03:00:55 来自手机 | 显示全部楼层
{"replyTo":"","text":"Is it an actual fridge or just a plug in?","replyToPid":0}
 楼主| 发表于 2019-2-8 23:10:34 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"It is an actual fridge in my truck"}
 楼主| 发表于 2019-2-9 04:34:49 来自手机 | 显示全部楼层
{"replyTo":"","text":"Its look like that is the problem. Got my local mechanic to help me change the batteries. Thanks a lot.","replyToPid":0}
发表于 2019-3-8 01:05:45 来自手机 | 显示全部楼层
{"replyTo":"","text":"A tech at the Freightliner dealership told me there is a problem with the connections for refrigerators in some freightliners and a service paper has been issued about it. It's a simple matter of them becoming disconnected by normal vibrations while driving. The fix is to bend the connection ends so that they can't separate.","replyToPid":0}
GMT+8, 2026-4-17 05:54 , Processed in 0.081291 second(s), 24 queries .
