查看: 355|回复: 7
Columbia Marker Lights HELP
 楼主| 发表于 2019-2-7 22:52:13 来自手机 | 显示全部楼层 |阅读模式
{"text":"Need help guys. the marker lights on my truck and trailer of 2006 columbia will stop working after a few miles of driving. Sitting in parking lights they will stay on but as soon as I start driving it happens. The turn signals, brake lights and headlights will stay on during driving, its just the marker lights. Any Ideas?","pics":"[]","canComment":true}
发表于 2019-2-8 23:14:09 来自手机 | 显示全部楼层
{"replyTo":"","text":"Sounds like a bad connection. Try checking the trailer cord plug at the front of the trailer.","replyToPid":0}
发表于 2019-2-8 03:06:10 来自手机 | 显示全部楼层
{"replyTo":"","text":"Funny. Getting the same problems with a 2005 model.","replyToPid":0}
 楼主| 发表于 2019-2-9 02:28:56 来自手机 | 显示全部楼层
{"replyTo":"","text":"Thanks, will start with that.","replyToPid":0}
发表于 2019-2-9 04:39:07 来自手机 | 显示全部楼层
{"replyTo":"","text":"Mine did the same thing. I replaced the light switch to fix it.","replyToPid":0}
发表于 2019-3-16 09:51:52 来自手机 | 显示全部楼层
{"replyTo":"","text":"It seems a wire which is disturbed when u drive due to wind and then when u stop it connects again. Check the wires as if the lights r working when u park nothing wrong with them.","replyToPid":0}
发表于 2019-5-19 11:06:17 来自手机 | 显示全部楼层
{"replyTo":"","text":"is it the Tractor or Trailer?","replyToPid":0}
发表于 2019-5-23 17:51:09 来自手机 | 显示全部楼层
{"replyTo":"","text":"check ur fuses","replyToPid":0}
GMT+8, 2026-4-17 08:06 , Processed in 0.201924 second(s), 24 queries .
