查看: 131|回复: 4
03 4300 Issue. NEED HELP
 楼主| 发表于 2019-2-7 22:28:28 来自手机 | 显示全部楼层 |阅读模式
{"text":"I own a 2003 International 4300 DT466. It charges and shows 14 on minute and then it will just quit and discharge. After that a light will be displaying on the dash. I have already tried changing the alternator. Any ideas on how to fix this?","pics":"[]","canComment":true}
发表于 2019-2-9 04:49:59 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"If that doesnt work still, test the alternator if the batteries test good. It wouldn't be the first time someone got a bad NIB alternator. Also, always make them test new parts at time of purchase. If they won't test it, buy from someone who will."}
发表于 2019-2-8 03:11:34 来自手机 | 显示全部楼层
{"replyTo":"","text":"Have you checked the wiring? Might just be a short","replyToPid":0}
 楼主| 发表于 2019-2-8 23:23:24 来自手机 | 显示全部楼层
{"replyTo":"","text":"Did that. Still doing the thing.","replyToPid":0}
发表于 2019-2-9 02:34:47 来自手机 | 显示全部楼层
{"replyTo":"","text":"Load test each battery. If one fails, all fails.","replyToPid":0}
GMT+8, 2026-2-4 07:58 , Processed in 0.076786 second(s), 24 queries .
