查看: 101|回复: 4
08 4300 Lights
 楼主| 发表于 2019-2-7 22:24:32 来自手机 | 显示全部楼层 |阅读模式
{"text":"I have a 2008 international 4300 truck that has its stop lights turn ON on their own while it was parked in my lot. I found 3 pressure switches under the steering column not knowing exactly which one belongs to the brake light system if any, but after I replaced all of those the lights still stay on. The new switches are the same specifications as the old ones and fitted in the right location each. \r\n\r\nHas someone had the same issue before? Some advice would be greatly appreciated\r\n","pics":"[]","canComment":true}
发表于 2019-2-8 03:12:18 来自手机 | 显示全部楼层
{"replyTo":"","text":"Got the same issue before. the brake light switch, which is mounted on the arm from under the dash, and the brake pedal rests on it, has a plastic bushing. it breaks and the light switch stays on.","replyToPid":0}
 楼主| 发表于 2019-2-8 23:24:42 来自手机 | 显示全部楼层
{"replyTo":"","text":"Is your truck equipped with hydraulic or air system? Mine is equipped with air brake system and there is not a switch at the pedal like you would normally see in almost any car or pick up truck with hydraulic system.","replyToPid":0}
发表于 2019-2-9 02:36:10 来自手机 | 显示全部楼层
{"replyTo":"","text":"air system, class 8 tractor. My mechanic showed me the location of the switch. i think it is up higher towards the dash area, but easy to get at. the \"plastic\" bushing breaks after x number of miles. the new bushing is the same material if i recall. it's been about 3 years ago? since mine was replaced, and frankly, i don't even have that truck anymore.","replyToPid":0}
 楼主| 发表于 2019-2-9 04:53:17 来自手机 | 显示全部楼层
{"replyTo":"","text":"Will look for it. Thanks for the help.","replyToPid":0}
GMT+8, 2026-2-4 07:58 , Processed in 0.063021 second(s), 23 queries .
