查看: 247|回复: 4
Airconditioning Issue
 楼主| 发表于 2019-2-7 22:17:25 来自手机 | 显示全部楼层 |阅读模式
{"text":"The airconditioning on my 2013 prostar is going warm on idle. It’s great while I am driving, just warm when on idle. Any thoughts?\r\n","pics":"[]","canComment":true}
 楼主| 发表于 2019-2-9 04:57:42 来自手机 | 显示全部楼层
{"replyTo":"","text":"Thanks you guys for the input. Problem now solved!","replyToPid":0}
 楼主| 发表于 2019-2-8 23:29:44 来自手机 | 显示全部楼层
{"replyTo":"","text":"Will try doing that. I appreciate the help.","replyToPid":0}
发表于 2019-2-8 03:14:35 来自手机 | 显示全部楼层
{"replyTo":"","text":"Looks like it needs a can of refrigerant. You can buy one at truckshops, the one with the hose on it. Idle your truck and just plug it in.","replyToPid":0}
发表于 2019-2-9 02:43:42 来自手机 | 显示全部楼层
{"replyTo":"","text":"Your system has discharged. You can try adding refrigerant, like they said, but if you can smell oil from the front of the hood or see neon green goo under there, it won't do much good. You'll need a compressor. If that's the case, have the shop check the condenser for pin holes. The bug screen on the inside of the grill can get loose and rub holes into the front of the condenser.","replyToPid":0}
GMT+8, 2026-4-16 13:00 , Processed in 0.070813 second(s), 24 queries .
