查看: 171|回复: 4
05 T800 Issue
 楼主| 发表于 2019-2-7 22:12:30 来自手机 | 显示全部楼层 |阅读模式
{"text":"Hi guys! I own a 05 t800 that keeps blowing the 10A fuse for the ACC feed which powers some gauges and also my speedo is stuck at 30km/hr. Is it just a possible that it has a shorted wire and if it is, is it going to be in the dash? thanks a lot.","pics":"[]","canComment":true}
发表于 2019-2-8 03:16:42 来自手机 | 显示全部楼层
{"replyTo":"","text":"having the same problem with my T700","replyToPid":0}
 楼主| 发表于 2019-2-8 23:31:10 来自手机 | 显示全部楼层
{"replyTo":"","text":"Fixed the problem, the operators had some wiring issues and tried to fix it. They have wired the ACC feed wire and the ignition feed together into the gauges and it has overloaded the circuit.","replyToPid":0}
发表于 2019-2-9 02:47:07 来自手机 | 显示全部楼层
{"replyTo":"","text":"Lesson learned, dont ever leave the tools to the wrong people.","replyToPid":0}
 楼主| 发表于 2019-2-9 05:00:19 来自手机 | 显示全部楼层
{"replyTo":"","text":"Yea right.","replyToPid":0}
GMT+8, 2026-3-21 06:09 , Processed in 0.070502 second(s), 23 queries .
