查看: 180|回复: 9
I-20 Rush Hour Traffic Recommnedations
 楼主| 发表于 2019-2-7 22:06:35 来自手机 | 显示全部楼层 |阅读模式
{"text":"Does anybody have any recommendation on how I can avoid the rush hour I-20 traffic by taking US-67 to the 171 which joins I-20 west of DFW in Weatherford? I was thinking of going that way today but stayed on I-20 which turned out to not be that bad. It's an extra 20 miles so I wasn't sure if it might be worth it.","pics":"[]","canComment":true}
发表于 2019-2-13 03:09:32 来自手机 | 显示全部楼层
{"replyTo":"","text":"Only takes one accident tho.","replyToPid":0}
发表于 2019-2-8 02:42:55 来自手机 | 显示全部楼层
{"replyTo":"","text":"That section of I-20 is rarely that bad. If you have to cross DFW, I 20 is the way to go, any time of day. Now if you observed a major crash through there in google maps, with 5 miles of stop and go, then deviation options might be worth looking into. I’ve not run across 171 but doesn’t look like a worthwhile option.","replyToPid":0}
发表于 2019-2-8 23:02:42 来自手机 | 显示全部楼层
{"replyTo":"","text":"I've run 171 many times. It's two lane but good road. But that's a lot out of the way to go from I20 down 67 to Cleburne then back up 171 to Weatherford. Maybe if there is a major freeway shutdown on I20. Otherwise, I20 is the best. Can get slow down the big hill until after 360 but still better than going the other way.","replyToPid":0}
 楼主| 发表于 2019-2-8 05:31:26 来自手机 | 显示全部楼层
{"replyTo":"","text":"Thanks.","replyToPid":0}
 楼主| 发表于 2019-2-9 02:18:25 来自手机 | 显示全部楼层
{"replyTo":"","text":"Alright. Thanks for the information.","replyToPid":0}
发表于 2019-2-9 04:19:32 来自手机 | 显示全部楼层
{"replyTo":"","text":"Ever try US 59 you could run that from Texarkana all the way down to Laredo.","replyToPid":0}
 楼主| 发表于 2019-2-11 20:46:36 来自手机 | 显示全部楼层
{"replyTo":"","text":"In this case, I was in South Dallas going west, more bypassing Fort Worth than Dallas, and didn't want to deal with I-20, especially since it was my third time that day. But I'll remember the Hwy 59 suggestion. Thanks!","replyToPid":0}
发表于 2019-2-11 23:25:18 来自手机 | 显示全部楼层
{"replyTo":"","text":"West of Fort Worth one is free to roam. Not so from east of Dallas. Important to have destination in mind. Doesn’t take much of a mistake from the east to compound a delay.","replyToPid":0}
发表于 2019-2-11 23:30:10 来自手机 | 显示全部楼层
{"replyTo":"","text":"There are some days you can cross all of dfw during rush hour using i20 with barely any slow down.","replyToPid":0}
GMT+8, 2026-3-21 08:12 , Processed in 0.071797 second(s), 24 queries .
