查看: 390|回复: 11
2007 M2 Breaklights Issue
 楼主| 发表于 2019-2-5 21:34:39 来自手机 | 显示全部楼层 |阅读模式
{"text":"Im having issues with my 2007 M2, when you step on the brakes the lights come on like a strobe then settle down and stays on.\r\n\r\nAny ideas???\r\n","pics":"[]","canComment":true}
发表于 2019-2-5 21:35:44 来自手机 | 显示全部楼层
{"replyTo":"","text":"Must be the pedal on the switch","replyToPid":0}
 楼主| 发表于 2019-2-5 21:36:35 来自手机 | 显示全部楼层
{"replyTo":"","text":"There is no switch on the pedal","replyToPid":0}
发表于 2019-2-8 03:02:51 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"My guess that it is switch in the loop somewhere. Try checking."}
发表于 2019-2-8 23:12:12 来自手机 | 显示全部楼层
{"replyTo":"","text":"This may be a recall issue. http://wemakeitsafer.com/vehicle-recall/Freightliner-Business-Class-M2-Recall-6794861","replyToPid":0}
 楼主| 发表于 2019-2-9 02:27:06 来自手机 | 显示全部楼层
{"replyTo":"","text":"Not According to Freightliner.","replyToPid":0}
发表于 2019-2-9 04:37:08 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"Got the same problem. Needed to talk to my local mechanic to have it checked out."}
发表于 2019-2-11 21:14:37 来自手机 | 显示全部楼层
{"replyTo":"","text":"Must be a one in a thousand case. Got 2 M2s and did not have any problem.","replyToPid":0}
 楼主| 发表于 2019-2-13 03:25:03 来自手机 | 显示全部楼层
{"replyTo":"","text":"What did your mechanic say Neon?","replyToPid":0}
发表于 2019-2-13 03:37:27 来自手机 | 显示全部楼层
{"replyTo":"","text":"Has there been a fix?","replyToPid":0}
GMT+8, 2026-4-17 07:30 , Processed in 0.072865 second(s), 23 queries .
