查看: 513|回复: 10
Safe Parking in Seattle
 楼主| 发表于 2019-1-31 21:50:44 来自手机 | 显示全部楼层 |阅读模式
{"text":"Does anyone know a good and safe place where I can park my rig at the Seattle/Tacoma area? I don't mind paying as long as it is safe.","pics":"[]","canComment":true}
发表于 2019-4-10 23:32:36 来自手机 | 显示全部楼层
{"replyTo":"","text":"There is no one where to park in Seattle. Closest truck stop on exit 34 of I90 or  exit 202 of I5","replyToPid":0}
发表于 2019-2-4 19:57:55 来自手机 | 显示全部楼层
{"replyTo":"","text":"Swift has a terminal nearby in Sumner. See if they will rent you a space.","replyToPid":0}
 楼主| 发表于 2019-2-8 02:44:28 来自手机 | 显示全部楼层
{"replyTo":"","text":"Thanks, I’ll check them out.","replyToPid":0}
发表于 2019-2-8 05:40:20 来自手机 | 显示全部楼层
{"replyTo":"","text":"Look for rv storage rental","replyToPid":0}
发表于 2019-2-8 23:06:01 来自手机 | 显示全部楼层
{"replyTo":"","text":"Truck only or trailer too? RV storage will likely be your best and most secure choice. Next would be reaching out to companies that have terminals there or maybe dealerships.","replyToPid":0}
 楼主| 发表于 2019-2-9 02:20:42 来自手机 | 显示全部楼层
{"replyTo":"","text":"Will keep them in mind. Are there no truck stops that are safe around the area?","replyToPid":0}
发表于 2019-2-11 20:48:51 来自手机 | 显示全部楼层
{"replyTo":"","text":"There are truck stops but I just wouldn’t call it safe.","replyToPid":0}
发表于 2019-2-11 23:19:20 来自手机 | 显示全部楼层
{"replyTo":"","text":"There is a truck stop in Sumner that charges $10 for every 12 hours, and that would add up very quickly.","replyToPid":0}
发表于 2019-2-13 03:10:55 来自手机 | 显示全部楼层
{"replyTo":"","text":"And you’d come back to a destroyed hood and no wheels or tires. Lol","replyToPid":0}
发表于 2019-2-13 03:16:11 来自手机 | 显示全部楼层
{"replyTo":"","text":"You’re pretty much screwed for parking there. Someone mentioned using a secure storage facility. I would second that idea.","replyToPid":0}
GMT+8, 2026-4-17 18:15 , Processed in 2.954295 second(s), 24 queries .
