查看: 202|回复: 11
Good Shop Recommendations
 楼主| 发表于 2019-1-31 20:03:04 来自手机 | 显示全部楼层 |阅读模式
{"text":"Hi guys. Im looking for a shop near or in Chicago that can replace my clutch at a reasonable price. I own a 2007 international with Eaton fuller 10 speed.","pics":"[]","canComment":true}
发表于 2019-2-4 17:36:48 来自手机 | 显示全部楼层
{"replyTo":"","text":"Try Truck Depot in Summit,IL.","replyToPid":0}
 楼主| 发表于 2019-2-8 00:11:34 来自手机 | 显示全部楼层
{"replyTo":"","text":"Will check on that.","replyToPid":0}
发表于 2019-2-8 04:32:01 来自手机 | 显示全部楼层
{"replyTo":"","text":"Have you tried googling one? Search for a place that specializes in drivetrain components.","replyToPid":0}
 楼主| 发表于 2019-2-8 22:13:44 来自手机 | 显示全部楼层
{"replyTo":"","text":"Yes. Just checking other options","replyToPid":0}
发表于 2019-2-9 00:42:52 来自手机 | 显示全部楼层
{"replyTo":"","text":"Diesel Master, Bedford Park, IL.","replyToPid":0}
 楼主| 发表于 2019-2-9 03:39:46 来自手机 | 显示全部楼层
{"replyTo":"","text":"Thanks.","replyToPid":0}
发表于 2019-2-11 18:04:18 来自手机 | 显示全部楼层
{"replyTo":"","text":"I replaced mine once on the road on my freightliner century,it took around $2000 for the parts and labor,so it should be less than that in Chicago.","replyToPid":0}
发表于 2019-2-11 18:04:31 来自手机 | 显示全部楼层
{"replyTo":"","text":"The parts alone if you use genuine Eaton will cost 850 to 950. I would say 1600 to $2000.00 total job.","replyToPid":0}
发表于 2019-2-11 19:50:31 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"Following this thread."}
GMT+8, 2026-4-17 21:53 , Processed in 0.071487 second(s), 23 queries .
