查看: 161|回复: 3
06 WS 4900 Inquiry
 楼主| 发表于 2019-1-31 14:32:43 来自手机 | 显示全部楼层 |阅读模式
{"text":"Currently having an 06 WS 4900. The charging system charges to 13.1. Afterwards it goes all the way to the 11 mark before coming on. Also when I run the apu it went to 14.3 one night and 12.3 the next 2, batteries were all tested As good, any ideas?","pics":"[]","canComment":true}
发表于 2019-2-4 15:52:13 来自手机 | 显示全部楼层
{"replyTo":"","text":"There could be a number of reasons why this is happening. I mean it could be a failing alternator/voltage regulator, faulty voltmeter gauge, wiring issue to voltmeter gauge, poor connections on the alternator circuit. Best advice is to have it checked by a mechanic.","replyToPid":0}
 楼主| 发表于 2019-2-8 03:47:47 来自手机 | 显示全部楼层
{"replyTo":"","text":"Alright. thanks.","replyToPid":0}
 楼主| 发表于 2019-2-8 03:47:54 来自手机 | 显示全部楼层
{"replyTo":"","text":"Anyone having the same issue?","replyToPid":0}
GMT+8, 2026-3-21 06:09 , Processed in 0.067031 second(s), 23 queries .
