查看: 178|回复: 3
05 T600 Cummins Issue
 楼主| 发表于 2019-1-30 22:23:05 来自手机 | 显示全部楼层 |阅读模式
{"text":"Need help everyone, my 05 t600 cummins blower motor just stopped working at all, I pulled it out and connected it to 12V, I also have a 12V connected at one of the wire connecting to the motor. So the problem is on the ground side. Any thoughts?","pics":"[]","canComment":true}
发表于 2019-2-4 15:37:12 来自手机 | 显示全部楼层
{"replyTo":"","text":"Did you try checking the resister?","replyToPid":0}
发表于 2019-2-8 03:36:18 来自手机 | 显示全部楼层
{"replyTo":"","text":"Howitzer is right. When my heater fan went bad. I had no power levels for a couple days.","replyToPid":0}
 楼主| 发表于 2019-2-8 23:56:20 来自手机 | 显示全部楼层
{"replyTo":"","text":"Thanks, will try to check that then.","replyToPid":0}
GMT+8, 2026-3-21 06:09 , Processed in 0.074190 second(s), 23 queries .
