查看: 277|回复: 6
Kenworth T600 Issue
 楼主| 发表于 2019-1-30 22:20:16 来自手机 | 显示全部楼层 |阅读模式
{"text":"Hi guys, I have been having issues with my 07 t600. My blinkers are not working, also some of the lights on the dash are always on when they shouldn't be. Any thoughts on this?","pics":"[]","canComment":true}
发表于 2019-2-4 15:33:27 来自手机 | 显示全部楼层
{"replyTo":"","text":"Have the same model. Following this thread in case this happens to me","replyToPid":0}
发表于 2019-2-8 03:33:54 来自手机 | 显示全部楼层
{"replyTo":"","text":"Start with the fuse, a blown fuse or tripped breakers can do a lot of damage.","replyToPid":0}
 楼主| 发表于 2019-2-8 23:54:38 来自手机 | 显示全部楼层
{"replyTo":"","text":"Check all the fuses, brought new blinkers. Hazard lights work, just no blinkers.","replyToPid":0}
发表于 2019-2-9 03:12:40 来自手机 | 显示全部楼层
{"replyTo":"","text":"Is the switch fried?","replyToPid":0}
 楼主| 发表于 2019-2-9 05:19:24 来自手机 | 显示全部楼层
{"replyTo":"","text":"Haven’t checked. Hopefully not.","replyToPid":0}
发表于 2019-3-4 19:07:42 来自手机 | 显示全部楼层
{"replyTo":"","text":"If you’re running in the north it’s most likely salt. I’ve given up on lights for the season. Get salt and brine in the connectors and it’ll corrode everything. Both front corner markers are out and both markers on rear of front fender are out. But blinkers work so I’m leaving them. I’ve got a connector corroding on my mid trailer blinker too that causes my turn arrow on my dash to stay illuminated as well. ","replyToPid":0}
GMT+8, 2026-3-21 06:09 , Processed in 0.066361 second(s), 24 queries .
