查看: 185|回复: 4
2000 W900 Manual and Schematics
 楼主| 发表于 2019-1-30 21:31:39 来自手机 | 显示全部楼层 |阅读模式
{"text":"Does anyone know where I can get manuals and schematics for my 2000 W900 without spending an arm and a leg? I am particularly looking for the schematic of the battery/alternator/ammeter circuit.","pics":"[]","canComment":true}
发表于 2019-2-4 14:53:29 来自手机 | 显示全部楼层
{"replyTo":"","text":"Tried doing a Google search and I got a bunch of possibles..\r\n\r\nsearch 2000 w900 wiring diag probably come right up. More likely it will be a PDF.","replyToPid":0}
 楼主| 发表于 2019-2-8 03:20:33 来自手机 | 显示全部楼层
{"replyTo":"","text":"Also, one of the switches on the instrument panel is for the \"sleeper dome light\", but I cannot find out what that's supposed to be, since the dome light is powered through a switch in the sleeper.","replyToPid":0}
发表于 2019-2-8 23:36:59 来自手机 | 显示全部楼层
{"replyTo":"","text":"Some trucks have a switch on the dash as well as in the sleeper so you can turn it on before you go to the bunk and turn it off when you are ready for bed so you don't have to get up.","replyToPid":0}
 楼主| 发表于 2019-2-9 02:58:47 来自手机 | 显示全部楼层
{"replyTo":"","text":"Got it. Thanks","replyToPid":0}
GMT+8, 2026-3-21 06:08 , Processed in 0.081452 second(s), 23 queries .
