查看: 173|回复: 4
2002 Kenworth T800 Issue
 楼主| 发表于 2019-1-30 21:28:52 来自手机 | 显示全部楼层 |阅读模式
{"text":"Hi Guys, I currently have a 2002 Kenworth T800. Here's my question.What would cause my left front fender turn signal to start blinking dimly when I turn on the right turn signal? My Dash indicator, mirror mounted signal and rear turn signals work normal. If I turn my marker lights on. The left front doesn't flash with the right side. Also if I turn the right signal on and the left front flashes, I can turn my dash light brightness knob and I can brighten or dim the left front signal.","pics":"[]","canComment":true}
发表于 2019-2-4 14:46:20 来自手机 | 显示全部楼层
{"replyTo":"","text":"Must be short somewhere. Does it happen on your other trailers?","replyToPid":0}
 楼主| 发表于 2019-2-8 03:18:45 来自手机 | 显示全部楼层
{"replyTo":"","text":"No. I have pulled the same trailer for the last 4 months.","replyToPid":0}
发表于 2019-2-8 23:33:37 来自手机 | 显示全部楼层
{"replyTo":"","text":"Well that eliminates a short from the trailer. Try checking the wiring from the signal light and work your way back.","replyToPid":0}
 楼主| 发表于 2019-2-9 02:53:59 来自手机 | 显示全部楼层
{"replyTo":"","text":"Will do that then, thanks","replyToPid":0}
GMT+8, 2026-3-21 06:09 , Processed in 0.061127 second(s), 25 queries .
